But I like my cartoons ... here is what the prototype apparently traveled over a million kilometers .. Well, but I would certainly do without 2/3 crankshaft and 4 connecting rods less ...
https://en.wikipedia.org/wiki/Commer_TS3
and here, in this photograph, it is perfectly visible that if you replace these connecting rods and the crankshaft for these 3 additional cylinders 9 Next 6 pistons), for which you can clearly see that the place is, and outside put one crank with two connecting rods, then the strong , pratically with the same dimensional parameters and the same could be more likely to have TWO TIMES more power ... If like comon rail to use, then surely and the plane would be suitable with such parameters ..
One idea was enough.
https://www.flickr.com/photos/31486821@ ... 8527/?rb=1
http://www.commer.co.nz/history
Well, if we were to convert the Rootes T4 version, then it would be 400 Hp with a good speed for the propeller.
Here in the movie you can hear that when they "defraud" it's almost like Formula 1 rolleyes
And it would be twice as good ...
https://www.youtube.com/watch?v=m5xOA53 ... e=youtu.be
A small crankshaft at the front and an additional lever ... I would have put in a good turbocharger yet, but I would leave mechanical roots, too... :love:
Commer Feliks
Andrew
