I read that Vettel stopped the car purposely as soon as possible to avoid any possible additional engine damage because of the engine limit this year. It was not because he ran out of fuel just after the finishing line.
What Hamilton is reported to have said is surprising (in the sense that one design can be so much more effective than the rest).
Jersey Tom wrote:It would be awfully easy for the ECU to just cut fuel to the one cylinder if it noticed said plug to be faulty.. without changing the mix to the other cylinders.
Having been involved with programable ECUs in a dyno room environment, I find this to be very unlikely.
It is of course possible but I have never come across the requirement in reality.
Turning off cylinders to save fuel is done, at least on road vehicles but I know of no such configuration in F1.
Perhaps someone can confirm this.
tok-tokkie wrote:I read that Vettel stopped the car purposely as soon as possible to avoid any possible additional engine damage because of the engine limit this year. It was not because he ran out of fuel just after the finishing line.
Perhaps he also turned off or failed to 'lock' the ride height system and it defaulted to maximum height?
There's a new version speculated -- that Vettel run out of fuel.
Pros -- it explains why on onboards from the final part of the race engine sound was the same as earlier. It should've changed if only 7 cylinders were firing?
Cons -- we heard Vettel on the radio "I'm loosing power, I'm loosing power" and why hide fuel consumption problem?
timbo wrote:There's a new version speculated -- that Vettel run out of fuel.
I think you will find that the rpm decreased after the problem. No doubt the fuel mixture was changed and the driver avoided the rpm where the problem showed itself. That is why the engine sounded much the same. I doubt the plug had totaly failed, they rarely do.
I do not think it was a major increase in fuel use but with a plug miss firing there definitely would have been a slight increase in fuel use.
IMO Vettel turned off the engine ASAP to conserve the engine and save fuel and finishing weight.
as Renault stated one cylinder was not firing and it was not related to a malfunctioning component on their side..there is not much left apart from a wiring harness problem and possibly a ECU trouble.The second one i´d say is quite unlikely ,
the first one could be as simple as a groundwire failure.
Of course loosing a cylinder will cause the scavenging of the other cylinders of that bank to be at least reduced or less than optimum,the power losses would be immense as a F! engione runs ample of valve overlap so cylinder filling relies
almost solely on what happens in inlet and exhaust piping ...so from say 800 horse
400 were running normal and of the other engine bank a reduction by 50% say 200HP
seems to be closer to what happened than asuming you have just lost one cylinder in the equation.The engine was not sounding healthy a simple loss of one cylinder would not sound like that.that unburned fuel in the exhaust surely has done no good to the remaining 3 cylinder behaviour .
marcush. wrote:as Renault stated one cylinder was not firing and it was not related to a malfunctioning component on their side..there is not much left apart from a wiring harness problem and possibly a ECU trouble.The second one i´d say is quite unlikely ,
As I mentioned in my last post, I very much doubt it was a 'complete' plug failure, this rarely happens even on race engines.
Well Ron Dennis say that its possible for the ECU software to shut down cylinders to save fuel.
Also I read this on Diario AS:
"The investigation to identify the reason for Vettel's engine problem is ongoing," he said.(Renault engineer)
"A small problem with the spark plug was found, but we have no reason to suspect a defect in the component itself."
Apparently there was a small issue with the spark plug but not enough to shut down the cylinder.
I Think Red Bull have overestimated the Renault V8's fuel saving qualities and have designed a smaller fuel tank. The low exiting exhausts point to this(smaller tank) as everyone was scratching their heads to know how Newey did it this way.
If it is the case Red Bull will either have to redesign(unlikely) or conserve fuel at some stage in the race(most likely given RB6 pace).
JohnsonsEvilTwin wrote:Well Ron Dennis say that its possible for the ECU software to shut down cylinders to save fuel.
i´m not sure how to interpret the statement coming from Renault..the component itself ,is that the sparkplug or the engine? maybe if the statement was translated from french something was lost or misinterpreted there.. what is a small issue on a sparkplug? and in anayways the sparkplug itself was not defective this is clear,as it is a component of the whole engine...
11/11/09
POWERTRAIN CONTROL UNIT
TAG-310B
TAG-310B is the main processing unit for complete powertrain control of a racing car. It may be used with companion driver units (eg IGN310 and ING310 or PB2006) to provide direct control of ignition and injection, along with all other powertrain control functions. The TAG-310B provides a powerful processing platform with minimum latencies for customer applications based on PowerPC processors. Application code is autocoded using our Graphical Development Environment (GDE) from Matlab/Simulink control modules. The unit comes with integral data logging and high speed communications capabilities.
The TAG-310B is configured by System Monitor and the logged data is displayed and analysed by ATLAS.
For example system configurations please refer to the Application Notes.
Electrical Supply Voltage 7.5 to 16V DC Supply Voltage not to exceed 17V continuous (the unit is protected against transients and reverse polarity) Supply Current quiescent (ignition off)
5mA typical @12V Supply Current operating (no load on inputs) 1.2A typical @13.8V Supply Current operating (max load on supplies) 3.0A typical @13.8V TAGOS 32-bit Real Time Operating System Application processing power 1700 MIPS Data retention not battery dependant Data logging memory 1Gbyte Flash, 16Mbyte SRAM
Mechanical Available with magnesium (chromate converted and painted with stippled black epoxy) or aluminium case (hard black anodised) Aluminium case weight 1300g Magnesium case weight 1130g
Electro Magnetic Compatibility Complies with the essential protection requirements of 89/336/EEC
Service
Recommended service interval 12 months (internal battery is replaced)
Application
Control and monitoring of complete powertrain 10 cylinder engine Throttle-by-wire Clutch-by-wire Semi-automatic gearbox
Powerful onboard data logging
Ethernet connection to application and data analysis tools
Connection definition Integral, sealed, military standard connectors
Front connector A
100 way
CGK-S0T 22N-35PN
Centre connector B
100 way
CGK-S0T 22N-35PB
Rear connector C
100 way
CGK-S0T 22N-35PC
For pin numbers, please request further details from our Technical Consultancy Department.
Environmental Splash resistant to standard motorsport fluids Lids sealed with O rings Maximum humidity 100% Minimum operating temperature 00C Internal Temperature not to exceed 700C as measured by internal diagnostic sensors Storage Temperature -100C to +850C Vibration 100 to 1000Hz, all axes, 24 hours Vibration isolation is recommended
11/11/09
TAG-310B
Sensor Inputs 47 General Purpose 0 to 5V 12bit Analogue inputs 15 0 to 5V 12bit Analogue inputs (10kHz) 16 General Purpose configurable 0 to 5V or Pt1000 10bit Analogue inputs 19 General Purpose 0 to 5V 10 bit Analogue inputs 3 Inductive speed sensor inputs 8 Hall speed sensor inputs 2 General purpose digital inputs 2 Wideband UEGO lambda interfaces (12bit) 1 Lap trigger interface 2 Thermocouple inputs (12bit)
Outputs 12 Moog drive stages 8 General Purpose Low side drive stages 4 Fast discharge low side drive stages 2 Fuel Pump drive stages 1 Sensor Node Supply drive stage 2 Lambda Heater drive stages 9 High Side, high power, drive stages 8 High Side, low power, drive stages 2 Oscilloscope diagnostic outputs or 0 to 5V Analogue outputs 1 TTL Digital output 1 Open Drain Digital Output 10 Open Drain TPU ignition control outputs 10 TTL digital TPU injector control outputs 5V and 10V output supplies for transducers
Communications 1 RS232 interface, up to 57.6kbps 6 CAN bus interfaces, up to 1Mbps 1 PCU dashboard comms 1 Wide band or Narrow band telemetry interface up to 16Mbps 1 Interface to MESL Sensor Nodes, 2Mbps asynchronous HDLC 1 Interface to System Monitor ATLAS, 100baseTX Ethernet link 1 Interface to STAR bus, 8Mbps synchronous HDLC 1 Differential engine synchronous timing signal 1 Differential time synchronous timing signal
Rear connector
Centre connector
Front connector
43 Analogue inputs (12bit)
4 Programmable Analogue/Pt1000
8 DHE speed inputs
1 digital input
4 High side output (1A)
1 High side output (5A)
4 Low side outputs (2A)
9 Moog outputs
14 Analogue inputs (10bit)
8 Programmable Analogue/Pt1000
10 Analogue inputs (12bit)
1 Digital input
2 Lambda inputs
2 High side output (1A)
2 High side output (2A)
4 Low side outputs
2 Lambda heater high side driver
2 Oscilloscope outputs
Sensor node drive stage
2 digital outputs
2 Fuel pump outputs
10 Low current open drain
10 TTL digital outputs
3 Moog outputs
Sensor Node interface
RS232 Communications
Telemetry interface
3 CAN bus interfaces
STAR bus interface
5 Analogue inputs (10bit)
8 Analogue inputs (12bit)
1 lap trigger input
1 Digital switch input
7 Moog outputs
2 High side outputs (1A)
2 High side outputs (7A)
1 Open drain digital
1 Diagnostic timing output
2 Scope outputs
1 Differential Engine Synch
1 Differential time synchro output
5 CAN bus interfaces
1 PCU comms
1 STAR bus interface
1 RS-232 interface
1 Telemetry interface
1 Ethernet comms
1 Sensor bus comms
11/11/09
TAG-310B
TAG-310B development system
Model based development
environment for control
strategies and processing
algorithms compiled for
embedded target
Model based code
GDE
ATLAS
Data analysis
System Monitor
Application tool Program version management
ECU reprogramming
Data tuning
Live parameter display
Puma link
ActiveX interface
CAN configuration
Data Acquisition configuration
Live data display via ethernet or wireless
Upload of logged data
Waveform, scatter, bar chart, histogram,
FFT display types
MATLAB export
Numeric functions
ActiveX interface
Upto 10 Cylinder engine control
62x 12bit and 35x 10bit 0-5V analogue i/ps
8x DHE inputs
34x drive stage o/ps
12x Moog valve drives
Lambda and thermocouple interfaces
100baseT ethernet, 6x CAN interfaces
1Gbyte Onboard logging memory and data
acquisition system
TAG-310B
Powertrain control unit
11/11/09
TAG-310B
Description TAG-310B Order Code O 030 072 013 002
Come on be real now. A small problem with a spark plug!
What else but a miss fire can it be?
Of course they are not going to compromise the plug supplier.
It is just one of those unfortunate faults that could happen at anytime to any plug.
