glenntws wrote:Tommy Cookers wrote:coplanar rods save only a little length (what roon said), as modern bores are large and modern bearings are small (reason coplanars are in museums)
articulated (one coplanar type) rods will give motion differences between banks
coplanar rods will be less suited to very high rpm, but seem plausible at current F1 mandated stroke and rpm used
the mandated 90 deg V could have a flat crank but still good balance, eg whole left bank firing simultaneously, then whole right
convention says rather poor for the turbo and for the crankshaft
You're right with the low stability of coplanar rods. They also cause different vibrations which are hard to control at 12k rpm.
However in my opinion your idea of big bang wouldn't really work. There would simply be way to much vibrations which are simply put not really attractive in a 12k rpm engine
I think a possible firing order is 1-4-3-6-2-5, which allows for 90° - 150° - ... seperation in firing. This would also mean that the exhaust manifold length of each cylinder simply has to have the same length to the main connection to achieve a very static pressure flow to the turbine which in turn means a more efficient turbo.
I was trying to say that in a 90 deg (3 throw) V whatever the crankshaft layout there's only secondary (ie rather small) force imbalance
eg three 90deg 1 throw (100% counterweighted) V twins would combine in different ways into a 90deg V6 with broadly similar results
eg a 0, 0, 0 deg crank, a 0, 240, 480 deg, a 0, 90, 180 deg ??, or something weird helping pulse feed to the turbo w or w/o cylinder cutting
eg Honda made conventional 0, 180 deg 2 throw V4 road motorcycles and then used a 0, 0 deg crank in race versions based on them
(only to get a stronger, higher rpm crankshaft within the dimensions dictated by the road machine design race rules - BB otherwise a myth)
the exhaust system imo has one runner longer than the other to (at typical rpm) equispace the pulses arrival at turbo (as single turbo Renault c.1978)
many/very many have said otherwise ie that the turbos are 'double-entry' (eg allowing equal or some other runner lengths)
