atanatizante wrote:@wuzak : Thanx a lot man for enlighten me with these things!
1.
wuzak wrote: The MGU-H could supply 10MJ to the system - if the turbine could provide enough power.
a)Why the turbine couldn`t provide enough power?
b)There are mandatory turbine dimensions/size? coz I didn`t find anything regarding this matter in the rules …
It is the limits of the system. They could extract more power, but that would affect the power of the engine and could reduce efficiency.
There are no mandatory turbine dimension sizes, only that it can only be a single stage turbine.
atanatizante wrote:2.
wuzak wrote:The MGU-K won't be recovering 2MJ per lap on most circuits - at least not from braking.
a)Why can`t MGU-K provide 2MJ per lap?
Coz to cope with 4MJ/lap this year isn`t MGU-K electric generator capability in the same amount with the electrical motor?
From The Renault Energy F1 release technical sheet :
“The MGU-K is connected to the crankshaft of the internal combustion engine and is capable of RECOVERING or PROVIDING power (limited to 120 kW or 160 bhp by the rules).”
b) Could MGU-K recover other energy than braking? Your sure it`s not solely from braking?
c) Last year they could recover energy solely from rear brakes, right? This year could they recover even at the front one?
The 2MJ limit has been answered.
The MGU-K can, theoretically, generate by adding a drag on the ICE, reducing the power to the wheels and storing the energy for later use.
atanatizante wrote:3.
wuzak wrote:No, the use of the MGU-H to power the MGU-K is not dependent on the ES.
Yeah I know that but was poor in explain it
So I know they could “split” the power for ES and for MGU-K ...
Yes.
atanatizante wrote:4.
wuzak wrote: It is unlikely that much of the MGU-H energy recovered will be sent to the ES.
a) Are you sure of that? I`m afraid it`s the other way around coz as I understand the MGU-H first priority is to harvest the ES with the remaining 2MJ/lap that MGU-K can`t do it due to the rules and in the end to reach the 4MJ/lap limit in order to get the max. power allowed for the latter …
b) Then what`s the reason behind the imposed rule for max. 4MJ/lap for ES?
Most of the time when the MGU-H will be harvesting will be when maximum or near maximum power is demanded. By routing the power from the MGU-H you lose energy through additional inefficiencies.
Not sure why the 4MJ rule was imposed. I suppose it enables some strategy play, where the ES isn't used to power the MGU-K for a few laps, while braking energy is stored. This then allows extra power for an attempt at overtaking (or at a fastest lap for someone like Seb).
atanatizante wrote:5.
wuzak wrote:And basically any time the engine is at full throttle the MGU-H will be sending energy to the MGU-K.
a) So what you are saying here is that, let`s say, from a 90 sec. lap a driver has 33,3 sec available to release the max. power – 120KW – provided by MGU-K (the max. power mapping scenario) and for the remaining 56,7 sec he could use what power MGU-H is sending to MGU-K ?
b) What power delivers this MGU-H, in general, we don`t know (but we could assume which amount it has, isn`t it?) and manufacturers has a free liberty regarding this matter, right?
c) And if it`s free to develop it then until when they have this liberty? or when MGU-H it`ll become a “frozen” spec?
a) on a track like Monza, with roughly an 85s lap, the MGU-H will probably be sending power to the MGU-K for 70s or more.
It is best to look at it the other way. If the MGU-H can supply 60kW of power, the ES only needs to supply 60kW of power. Thus the 4MJ limit will last 67s.
b) We don't have a certain idea of what power the MGU-H will deliver.
However, there have been some graphs produced by Cosworth that indicate that the MGU-H provides ~110hp @ 12,000rpm (ICE) and up to 120hp towards 15,000rpm (but over all power is reduced). Useful power is generated by the MGU-H over ~8,000rpm.
c) Development is restricted. Generally, though, the aim is to improve efficiency, and this is one area that can help to deliver that.
Also, the long term plan for these rules is that the fuel flow limit will be reduced. The electrical power side of this should, therefore, be increased o compensate for power loss of the ICE.
atanatizante wrote:6.
wuzak wrote:Some energy will be sent from the MGU-H to the ES, if only to be later used for spooling up the turbo.
So what you are implying is that they`d never use 4MJ/lap from ES solely for MGU-K coz they need energy for MGU-H in order to decrease turbo lag?
There is no limit as to the energy transfer between the ES and the MGU-H. The only limiting factor is the maximum storage of the ES, which is also 4MJ. My understanding of that is that you can transfer any amount in or out, so long as there is no more than 4MJ stored at any one time.
The other limit, 4MJ, applies only to transfer from the ES to the MGU-K.
atanatizante wrote:7.
wuzak wrote:The MGU-H is linked via a fixed gearing ratio and clutch to the turbo
a) Where in the rules states which gearing size is mandatory?
b) Or they have freedom with it?
c) In this case why not have the same speed like ICE?
Gearing is not mandatory, but since the turbo is allowed to spin at 125,00rpm it is probably advisable.
The regulations specify:
5.2.4 The MGU-H must be solely mechanically linked to the exhaust turbine of a pressure charging system. This mechanical link must be of fixed speed ratio to the exhaust turbine and may be clutched.
