But if it´s a correlation problem with the front wing, what´s to say everything else is correlated?
And if the front wing essentially rules the aerodynamics over the car it must mean everything else probably isn´t working as
intended?
Chances are good that they are getting what they intended from the car, but that intention is not what is required by the tires at a particular track.Nando wrote:..... mean everything else probably isn´t working as intended?
i'd have to agree with you!bhallg2k wrote:I hate to even go here, but it could be an issue with the aerodynamics of the front suspension. Yes, pull rods have been used on the front before, but not like this. The very nature of the suspension means that everything the team is doing aerodynamically has never been done before in this area. So, it's natural there would be hiccups.
Of course, the Hungaroring, despite what's held as conventional wisdom, is the "most aerodynamic" circuit of the season. It's the bastard child of Monaco and Silverstone. That makes it a great venue to test solutions, because nowhere else are the aerodynamic demands so extreme. That testing, regardless of anything else, could easily be enough to set off the hyperactive Italian media. They see loads of FloVis and testing arrays and then assume the sky is falling when really the team is just gaining knowledge because of a circuit's unique aerodynamic characteristics.
That's not to say there's nothing wrong or even that something is definitely wrong. It's just to point out that not everything is always as it seems.
A front pull rod shouldn't have such an unexpected influence on aerodynamic.bhallg2k wrote:I hate to even go here, but it could be an issue with the aerodynamics of the front suspension. Yes, pull rods have been used on the front before, but not like this. The very nature of the suspension means that everything the team is doing aerodynamically has never been done before in this area. So, it's natural there would be hiccups.
The rear part of it does that, the openings increase flow under the wing elements by feeding air into itbhallg2k wrote:I could be wrong, but I think the slots in the front wing end plates are more about air flow around the front tires, and that changes from circuit to circuit. The "real issue," for lack of a better term, with these "new" front wings is the flap.
I didn't know that they test the flap and don't race it for some weeks. The shape of the raced flag (with the indentation) makes me suspect, that it directs air around the tire in a rather steep angle. Maybe they try a smoother approach to have more air under the nose with little sideways momentum (i.e. more energy in longitudinal direction). That would point to your theory of aiming the flow the sidepods, bargeboards, floor beginning and turning vanes.bhallg2k wrote: Regardless of the end plates, the flap seen on the top wing is always present when tested, and the area downstream to that flap is the area of the car under such heavy scrutiny by the team these days. When the race comes around, the team always reverts to the lower wing with the indented flap.
I just meant, that the difference of pull/push rods is not that great. Together with the ever increasing concentration of aiming every flow precisely over a long distance, I don't think that the old data is so helpful. We will probably never know, could be some aftermath from the new-windtunnel-thingy (takes a few years to break them in to the extend that e.g. McLaren has).bhallg2k wrote:I'm not saying the pull rod is detrimental or beneficial in this specific area either way. Just that it's different. Teams have years of CFD and wind tunnel data on push rod setups. Ferrari has a year of CFD and wind tunnel data on their pull rod setup.
Another thing to consider is the effect of the wing flap on brake cooling. Ferrari has scoopless brake ducts that may not get enough flow with the more rounded wing flap.
There's just a lot going on, and, sadly, all we have to rely upon is speculation. (But, we're pretty good at that. So, maybe it's not all bad.)
Crucial X, time to find out about those update options mate! [-o<Redragon wrote:Alonso on his interview on last race, not only said the car was the same for the last 4 races
also said that they are working in two ideas to improve the car in future and he is optimistic
about it.
Also Domenacelli said the major update will be at SingapureChuckjr wrote:Crucial X, time to find out about those update options mate! [-o<Redragon wrote:Alonso on his interview on last race, not only said the car was the same for the last 4 races
about it.
Let's hope track testing matches windtunnel data this time.Redragon wrote:Also Domenacelli said the major update will be at SingapureChuckjr wrote:Crucial X, time to find out about those update options mate! [-o<Redragon wrote:Alonso on his interview on last race, not only said the car was the same for the last 4 races
about it.
