Because the regulations are so strict these days, and little else on the car visibly changes throughout the course of a season, the monkey seat has become, in my view, the most overhyped aerodynamic component in F1. Adding very little
directly in terms of both downforce and drag, it doesn't do much more than help air flow stay attached to the underside of the rear wing. That means its value is more or less proportional to the wing's camber/AoA, and the rear wing on SF16-H isn't quite as aggressive as the one typically used on SF15-T...
That's not to say the car wouldn't benefit from one at some point - and it seems to already be fitted with the necessary mount - just that it's probably pretty low on the agenda, given the significant changes made this year. A monkey seat polishes performance, so to speak, and this car is still being painted.
