Restomaniac wrote: ↑05 Dec 2021, 15:21
Gillian wrote: ↑05 Dec 2021, 15:14
Magicsenna_41 wrote: ↑05 Dec 2021, 14:56
The 0.4sec are in comparison to Verstappens previous fast lap and what we see on the dashboard.
So he was at that point maybe 0.2s clear to Hamilton.
Exactly.
Verstappen did not have pole in the bag like that. He went all in because that was the only way to get pole position. When the front tire locked he had to choose between waiting a little longer to accelerate or try and make it. Imo he should have bailed out but in that split second he choose to try and make it.
If he had bailed out the result would have been the same but no damage.
There was no margin to take it easy and safely roll to pole position...
Who said take it easy? I said it’s about knowing when you don’t need to keep pushing like mad. Wanna know when that is? When you’ve got time in your pocket with 1 corner to go.
I agree with that, truly do. But you misunderstand the sequence of events.
What happened is Verstappen locked a front tire and with that, all advantage he had was gone. You can check the live timings if you don't believe it.
The mistake Verstappen made came after that. He went on the throttle too early. If he had not done that, he would not have hit the wall. But he would not have had pole either. That's a mistake I think any driver fighting for a WDC would have made.
The logic you are applying is he should have taken the entire last corner easier. That implies he tried to gain more time in that last corner. If that's the case, I agree with you.
It's however not. Check back his qualifying laps and you will see he did not do anything weird in the last corner. If anything, he braked similar to his former lap which means he already wasn't as "on edge" as he had been the entire lap.
If you check the footage and still don't agree that's fine. I will shut up now.
