mwillems wrote: ↑09 Jun 2024, 02:20
Always nice to see hi-res shots of the cars in the wet.
I'd not noticed before quite how much the front wing endplates angle outwards at the rear to push away the air on the outside of the wing and create a low pressure zone in front of the tyres that helps the loaded airflow coming over and away the front wing get pulled further away from the tyre.
https://pbs.twimg.com/media/GPfwf_ZbEAI ... ame=medium
It seems that similar end plates appeared from Singapore 2023. It is curious how strongly the lower part of the rear wing end plate is curved outward in the area of the brake channels and the area of the beam wing joint. A kind of imitation of a diffuser increasing in volume? Perhaps this allows for more intensive air extraction from under the floor.
I checked the photos from the updated Silverstone 2023 spec front wing, there is no such outward bend.
Edit: I found it. In Singapore, only Lando received the updated front wing.
