hardingfv32 wrote:Is the exhaust is going to reduce the angle (stretch) the helix shape of the vortex?
In the case of most of the cars, the exhaust driven diffuser vortex only has the about length of the tire to function. How may helix revolutions might be formed in that distance? Could there only be enough distance to form the initial rev/twist?
What might I research under to gain more info on the this type of vortex formation? Almost everything I have found is aviation specific.
Brian
I could be wrong, but I seem to remember some articles on heated vortices exiting jet engines. Though I would think the properties of combustion exhaust would be different, but I regress that I know not much about jet motors and their production of power and the temps following the motor....
In the years spent with ground effect tunnels, ambient air vortex flow generation were common studies in the windtunnel, mainly for their sealing of gaps outboard and sealing properties inboard, mostly forward of the mouth of the tunnel, ( meaning inboard and outboard of the tunnels). When the rules allowed, we had put strakes inside the tunnels for vortex generator towards the exit, but again these were ambient vortex production.
Of the highest interest was the rear tires and sealing them away from the tunnels, the gains are massive in prevention of not only the wheel "air pumps" but also the tires turbulence bridging the gaps below the tunnels. The gains were in the CP movement and how sensitive it was to this air flow at the rear of the tunnel.
"Driving a car as fast as possible (in a race) is all about maintaining the highest possible acceleration level in the appropriate direction." Peter Wright,Techical Director, Team Lotus
