"Let's just all agree it's magic."
It is only magic if you are not willing to learn what in fact is the actual science.
Brian
Brian, I read that paper before.hardingfv32 wrote:hollowBallistix and vonk
You should both read:
Experimental study of multiple-channel automotive underbody diffusers
http://pid.sagepub.com/content/224/7/865.full.pdf+html
hollowBallistix, at the start of the study it states how/why the diffuser functions. It differs from your ideas.
vonk, in the main body of the report there are actual pressure tap test results that show, that in fact, the diffuser functions as/in open system.
Brian
n_anirudh, these pictures are fantastic. Do you have any of the 2011 Red Bull? Ferrari’s looks almost like a horizontal diffuser.n_anirudh wrote:
OK, here is a simpler single diffuser from this year. Ferrari /Massa 2011 Spain.
there is no step change and is a smooth transition
OK this is from 2010 oz Gp when PdlRosa stopped in front of me..sauber 2010 double diffuser:
This should pretty much be convincing.
Xcellent post harding, those kind of one-liners are rather useless and doesn't contribute whatsoever.hardingfv32 wrote:"Let's just all agree it's magic."
Brian
Total energy loss of the gas as it flows through the diffuser.vonk wrote:I agree about the definition of a diffuser. The term diffuser for devices of this kind has been around for a long time. Has it become a misnomer for what the picture shows? But that’s sacrilege, I know.n smikle wrote:This would break the definition of a diffuser though. You would see massive pressure loss with this abrupt expansion.
Could you explain what pressure loss you are referring to?
What applications? Any photos. I am reserved about this because I know it can work for one reason, but it will have energy losses for another.hardingfv32 wrote:n smikle
"This would break the definition of a diffuser though. You would see massive pressure loss with this abrupt expansion."
Agreed, but why would a competitive F1 car have this shape diffuser then. With further research I have found other examples of concave diffusers.
What other parts of the system are making this viable?
Brian
It speeds up the air under the car relative to the top. For argument's sake let's assume you could keep air perfectly attached to a pair of surfaces(I know it's impossible please bear with me). Viewing one side of the surface you notice it's smooth the other has a curve, assuming the air stays attached, the air on the smoother side of the surface will travel relatively faster than the air that has to go around the curve. Just like it's easier to pedal a bike on a flat road than uphill even though the same distance is covered.hardingfv32 wrote:xpensive
How does the concave shape of the diffuser roof specifically "help speeding up the air under the car"
Brian
I wouldn't know what specific effect the concave diffuser would have, in all honesty I had no idea they used that shape.hardingfv32 wrote:xpensive
Brian
I believe you are talking about a massive increase of turbulence. This would be true if it weren’t for the (possible) Kamm Effect.n smikle wrote:Total energy loss of the gas as it flows through the diffuser.vonk wrote:I agree about the definition of a diffuser. The term diffuser for devices of this kind has been around for a long time. Has it become a misnomer for what the picture shows? But that’s sacrilege, I know.n smikle wrote:This would break the definition of a diffuser though. You would see massive pressure loss with this abrupt expansion.
Energy in the form of pressure. Total pressure = static pressure + dynamic pressure. I mean loss in dynamic pressure, (sorry for the confusion) and a rise in static pressure, but overall a loss in total pressure in the form of heat.
Shelly,shelly wrote:Diffuser is not just about smooth transition of fast flow under the flat floor.
Suction peak is on the kink line; after that, a concave shape will give you a more aggressive pressure recovery.
The two dirvers of underbody performance aree the two suction peaks on the underbody leading edge and on the kink line.
One must take into account th 3dimensionality of flow and the presence of strakes which generate vortices at thier edges. The fences start at the kinkline and enhance the low pressure in the channels, abit upstream and a bit downstream of their leading edge
