Putting all that silliness aside, that is one Espace that I would dearly love to drive!
![Dancing \:D/](./images/smilies/eusa_dance.gif)
You do know that I have lived in the Appalachians, don't you MOWOG?MOWOG wrote:Ahhhh, that is most interesting. Thank you both for illuminating me. But X, here is a question for you - do we really have ten fingers or 8 fingers and two thumbs? Is a thumb a finger or is it something else entirely?
Exactly, ignore most of the video. It's the last few seconds on the last pass that I'm interested in. The rest of it just confirms it's a turbocharged engine. It's indeed pottering around mostly, then holds a gear for a short burst of WOT to higher revs. That frequency sounds like fairly high revs to me.Ogami musashi wrote:It sounds low frequency in the begining simply because they are going slow (if you listen to the subsequent main straight you'll hear the driver does not even shift) but the last pass the engine is quite high pitched (true not as mush as V10 or V8).Holm86 wrote:This sounds way too low frequency to be a 1.6 turbo V6 that does 15.000 revs.
Either this is the LaFerrari V12 or it is a test mule with a V6 engine form an upcoming Ferrari California which is rumored to feature a V6 turbo engine in its next generation.
That is a Blow-Off valve, isn't it? Also, as discussed in the general 2014 engine thread, it is not clear that F1 engines would have a waste gate, I imagine, to make the most of the exhaust energy in the MGUH.Ferraripilot wrote:That's it, it's just not being revved. 1:34 you hear the waste gate clear are day.
The new F1 engines don't run wastegates.jamsbong wrote:I think it is difficult to make out if it is a V6 because turbo muffles the engine tone. The Pagani Huayra is a good example of a V12 that has lost its beautiful voice because blocked by turbo.
One thing is clear, it is a force induction engine with a HUGE wastegate. Also the deep tone indicates a large diameter exhaust.
Although not the same noise, I quite like it. Like the Audi Quattro in Group B rallies, the sound is unique. I think if this is the 2014 F1 engine, all fans will be happy... And Bernie will be happy too as long as he gets the $$$. LOL.
are you sure that it is a wastegate? to me sounds more like a pop offecapox wrote:We have suggested, and calculated, here that they will not run a wastegate. It has yet to be proven. It is possible that Ferrari will do something different than what you all have calculated.
In that video, there is a wastegate. But is that the Ferrari v6?? Who knows.
Oh OK.Kai wrote:The new F1 engines don't run wastegates.
