Lotus E22 Renault
andrewf1
Re: Lotus E22 Renault
gobjb wrote:
andrewf1 wrote:
adrianjordan wrote:Isn't "horizontal projection" effectively when viewed from the side?
If so then wouldn't that allow for the walrus nose anyway regardless of whether the word single is in there or not??
Horizontal projection means viewed from the top.
Actually it means viewed from the front. Horizontal projection gives a vertical cross section.
No...horizontal projection means a projection made on a horizontal plane - which is a plane parallel to the x (and y) axis, or the horizont (all points have the same z coordinate). So, viewed from the top. You're confusing it with the term 'projected onto the horizont', which is not the same thing.
BorisTheBlade
32
The real benefit of the nose solution will be seen as soon as we get a front view. I like how they formed the rear crash structure as a wing as well.
madly
madly
There is no central pylon from this view? #-o
EDIT nevermind
Racecar Engineering also understands from sources within the team that the E22 has a ver clever mechanism for transmitting torque from the power unit to the transmission, which offere much greater performance than others seen by some team suppliers.
This sums it up nicely for me... In both looks and reaction...
clipsy1H
-16
darkmninya wrote:This car looks like a winning car
only if race alone :mrgreen: nose is so funny !! not even equal.
Rikhart
Rikhart
roadie wrote:Yeah the packaging at the rear looks tight.
Racecar Engineering are reporting:
Racecar Engineering also understands from sources within the team that the E22 has a very clever mechanism for transmitting torque from the power unit to the transmission, which offers much greater performance than others seen by some team suppliers.
http://www.racecar-engineering.com/cars/lotus-e22/
Well if the E22 has such a clever mechanism, then half the grid will have it/already has it, because of the personnel exodus from Lotus.
Holm86
249
madly
madly
Playing with level curves to check, what'a in the mouth. E22 say AAAA!
When I see E22 and MP4-29 I think the are both interface compatible ;-) Female E22 nose socket to male MP4-29 nose finger-plug :lol:
tok-tokkie
tok-tokkie
38
It is sad that this team which has original & interesting ideas is short of money & losing so much of its senior staff. To me the 2 tusks are not attractive aesthetically but I admire the technical merits of the idea. (But I also liked the forward exhaust idea - which turned out to be unsuccessful.)
madly wrote:Playing with level curves to check, what'a in the mouth. E22 say AAAA!
http://clients.madmultimedia.pl/priv/e2 ... detail.jpg
Plot twist: the E22 isn't a female, but instead has two shafts. If you know what I mean.
I wouldn't be surprised if this render turns out to be a joke from Lotus just to hijack McLaren's launch.
imightbewrong
imightbewrong
Three has been some serious image manipulation done on the nose, just after the split. What are they not showing?
Or maybe this is just the version that didnt pass the crash tests / or has been atlawed by the FIA
emmepi27
emmepi27
141
eheheheheh :lol:
FrukostScones
163
more like Naughty UK dogging adventures. Max Power to the people!
