Do they want to? It costs more money to run one, quite a lot more, and that could be spend on R&D to make the car go faster.
But you get the benefit of more miles and more setup changes to try, so you can make the car faster in that way.
So... Just a random thought here, and I know it might be going contrary to many of the popular Alonso rumors, but if the top three teams were obliged to run a third car next year (and if Ferrari happens to finish the season in the top 3), then might it make sense that Ferrari may want Vettel in order to cover their bases in terms of ensure two quality drivers if Alonso leaves, but also in that it gives them a strong 3-driver line-up if in-fact they keep Alonso and and do need to field three cars next year? As engine supplier to Marussia and Sauber, they must have some inside knowledge as to the state of finances there and thus the likelihood that the three-car thing might actually go forward for next year?Skippon wrote:I was told that in the concord agreement it was the top three teams that would be obliged to run third cars.
Which at the time meant Red Bull, Ferrari and McLaren !!
Sauce?Jonnycraig wrote:Confirmed that Caterham & Marussia are both skipping Austin.
I still think to qualify you should have to set a time within 107% of the fastest time. If you don't qualify, you don't race. It should be that simple.Jonnycraig wrote:With Vettel & potentially Alonso changing to 6th engines and thus not qualifing, they might as well skip Q1.
You do have to. You can't just ignore practice times though as anyone who smashed a car up in FP3 would miss the race.SiLo wrote:I still think to qualify you should have to set a time within 107% of the fastest time. If you don't qualify, you don't race. It should be that simple.Jonnycraig wrote:With Vettel & potentially Alonso changing to 6th engines and thus not qualifing, they might as well skip Q1.
That's a pretty huge leap of logic... It could just be that they have a very good chassis. Williams for example have shown no such ability.Manoah2u wrote:Mercedes showed utter dominance not just the entire year by running @ the front from start to finish, but also from falling to the back and finishing 2nd (nico) if the car is still intact and the tires will work accordingly. Thus, their power benefit must be huge.
Possibly, but it's not what Mercedes are doing. If that were the case they would have burned up their 5th engine with 7 or 8 races still to go. Instead, they burned it with 5 to go, and then went back to their 4th for the next race. That means their 5th engine will do 4 races (exactly the number you'd expect), assuming no fatal issues.in other words; is it worth taking the penalties for the benefit of power, or is it not humanely possible to gain enough power benefit compared to reliability?
ps. i wasn't referring to Mercedes having such power benefit they can afford this theory. i just noticed how 'easy' they blast from the back to the front, and got me thinking.Moose wrote:That's a pretty huge leap of logic... It could just be that they have a very good chassis. Williams for example have shown no such ability.Manoah2u wrote:Mercedes showed utter dominance not just the entire year by running @ the front from start to finish, but also from falling to the back and finishing 2nd (nico) if the car is still intact and the tires will work accordingly. Thus, their power benefit must be huge.
again, i was not referring to mercedes at all. I used them as example in how to blast from the back to the front, not them as actually doing this theory in real life, sorry if i caused this confusion.Moose wrote:Possibly, but it's not what Mercedes are doing. If that were the case they would have burned up their 5th engine with 7 or 8 races still to go. Instead, they burned it with 5 to go, and then went back to their 4th for the next race. That means their 5th engine will do 4 races (exactly the number you'd expect), assuming no fatal issues.Manoah2u wrote: in other words; is it worth taking the penalties for the benefit of power, or is it not humanely possible to gain enough power benefit compared to reliability?
Rules will be unchanged. 2,6,10. Vettel isn't bothering though, and rumour is that Alonso won't either due to 6th engines.Moose wrote:So this means we'll lose 4 in Q1 and 2? Or do we lose 5 and have a top 8 shootout?
