Williams FW37 Mercedes
Re: Williams FW37 Mercedes
The display.
LookBackTime
LookBackTime
472
Looks bigger than McLaren display! Am I wrong?
I really like Williams solution :)
WaikeCU
There's one downside: When you are turning, you can't see the display, because the steering wheel is in the way, whereas steering wheels with a display can be read at all times.
FrukostScones
163
michaelclarke
PlatinumZealot wrote:Can it get any tighter than that?!
I think they got it a bit tighter lat year. I remember they introduced this bodywork in Japan:
Last year they tightened it up enough that blisters were needed for the suspension mountings on the gearbox. That being said, this is only testing and they may be running more heat from a more powerful engine.
“Keep learning, you’ll never know everything… Never think you’re the best, because you probably aren’t. And always strive to be the best; that is working hard and keep learning.” – Jensen Button.
Cuky
65
LookBackTime wrote:Looks bigger than McLaren display! Am I wrong?
Those are all same displays. Different steering wheel layouts make them look bigger or smaller for different teams.
WaikeCU wrote:There's one downside: When you are turning, you can't see the display, because the steering wheel is in the way, whereas steering wheels with a display can be read at all times.
When you are turning with speeds they are doing you don't really look at display as you are trying to get as good line as you can.
3jawchuck
3jawchuck
37
I think they're the same, in fact I think McLaren electronics make those types of displays as a standard part.
http://images.adrivo.com/images/950/q_8 ... 625044.jpg
They can't get this tight anymore around the gearbox anymore because they are routing hot air to this part of the car.
Underneath it it's still very tight, look at the shadow under the Mercedes sign.
FrukostScones
163
triptube
triptube
https://www.youtube.com/watch?v=jtE8D89 ... ploademail
Great video from Massa in the FW-37 ! Sorry, it´s only in Spanish language.
desl
desl
37
There might be some situations, when you can read a display in a Williams better than in a car where the display is integrated in the steering wheel ;)
Might be good to have both options....
Juzh
161
I believe all teams use the same mclaren designed pcu-8d screen as of 2015.
http://www.mclarenelectronics.com/Produ ... uct/PCU-8D
OO7
OO7
171
Historically a drivers focus will not be on the steering wheel when s/he is negotiating a bend, so either way is fine.
New bit to the tire squirt area.
Some detail shots of the rear.
