McLaren MP4-31 Honda
ME4ME
79
Re: Mclaren MP4-31 Honda
One of the more interesting parts of the car is the floor around the rear tyres, or lack of floor, so to say.
KingHamilton01
Clear that they have gone with a lot more rake looking at the previous posts, so I believe they are on the right track. People seem upset and disappointed at the lack of clear changes from last year's car. However if there are concepts that they want to pursue then is bringing it to the car for the press release the best idea? Let's wait until second week at Barcelona, pretty sure we will see some changes come.
Plus if someone comes up with an innovative idea once they turn up to testing then normally every team will try and come up with there own version/solution. I like the subtle changes to the car, I like the curves on the nose and the slot in the FW pylons, nice RW endplates to there Red bull inspired imo. Looking forward to seeing what happen's in the test now!
McLaren Mercedes
I don't think you can read anything into the rake until it's actually running on track.
trinidefender
trinidefender
318
Part 1.
- Starting from the front, the space around the nose tip has been increased. The nose flanking the thumb has been raised to allow more airflow underneath. Definite slot in the front wing support plate, maybe along with the increased space around the thumb McLaren are trying to accelerate airflow more leading toward the turning vanes under the nose.
- The front wing looks like one of the variants they used at the end of last year. I would be a little surprised if this is the wing used used all throughout testing
- Under the nose the turning vanes look similar to what was used at the end of last season. On key difference that I see (that I do no believe is an artefact purely of camera angle etc) is the space between the T-tray and the bottom of the nose. It looks like McLaren made the base of the nose (where the drivers legs are) narrower vertically and continued this resulting in a thinner detachable nose section.
- T-tray looks lower however this is usually not shown in very high detail during car launches as, along with the diffuser, a place the manufacturer wants to keep hidden as long as possible. As such I'll reserve comment there.
- The S-duct looks like it actually starts further forward on the nose than last year, slightly surprising to me as I expected it to move backward toward the large nose angle change. The angle change looks as though it is has increased somewhat, maybe in conjunction with the narrower (vertically) front crash structure/nose, McLaren are trying to maximise the effectiveness of the floor.
- Barge boards keep their curved single profile, can't tell if much change there.
- I believe in some shots the raised lip along the front/side of the floor has the extra flap as used in various forms last year. The lip itself looks longer.
- Sidepods look to have a larger undercut than last year. With a similar total volume and air intakes (very hard to judge from these pics so I can be very wrong about this).
- Head protection has increased due to regulations. Continuing back from this it appears that more area has been allowed in the area between the sidepods and the vertical section behind the roll hoop. Can't tell if this is due to packaging of new Honda or if simply due to relocation of components.
- Roll hoop intake has be shaped slightly differently, looks more round in some shots. Still split with an upper and lower section. New and larger intake below roll hoop. Was a small hole on last seasons car however has been opened up to a significant area now. Thoughts as far as this goes leaves at least a few possibilities:
(I) more airflow to some critical components/areas on the PU that may have not received enough last year (or simply to cope with increased capacity from more powerful components) such as the between the V or the MGU-H.
(II) works in conjunction with the larger space mentioned between the sidepods and vertical section for maybe relocated components.
(III) feeds a relocated cooler.
- Vertical area behind the hoop/air box seem similar shape to the later portions of last seasons car minus the small shark fin that was on the 30 car.
End of part 1.
foxivan
foxivan
is it my illusion or the engine seemed to be mounted a bit lower than mp4-30?
a1b2i3r45
New extended brake duct ? or was it there last year ?
Egresi Tamás
Egresi Tamás
a1b2i3r45 wrote:New extended brake duct ? or was it there last year ?
http://i.imgur.com/5dmnPU9.jpg
Yes! That's an new brake duct.
frosty125
frosty125
Full Racecar Engineering Article, this Time even with Pictures.
http://www.racecar-engineering.com/cars/mclaren-mp4-31/
Edit: And an Analysis from Giorgio Piola and Matt Somerfield:
http://www.motorsport.com/f1/news/tech- ... 31-674728/
DarkAlman
DarkAlman
ummm, they ran the rear wing support through the exhaust pipe?
I realize STR came up with this idea, but it just occurred to me, could they put an exhaust duct in there to do something F-duct related?
domh245
domh245
30
DarkAlman wrote:ummm, they ran the rear wing support through the exhaust pipe?
I don't think you would be able to, in the regulations it states:
Engine exhaust systems must have only a single turbine tailpipe ...
...All and only the turbine exit exhaust gases must pass through the turbine tailpipe
which I would take to mean that you can't run exhaust gas through a central pylon.
GoranF1
GoranF1
151
It will be intersting to see if they run monkey seat from the go, last year they didnt want to put any unneeded drag on due to their power deficit.
Monkey seat could the first clue to progress tommorow morning.
Fer.Fan
Fer.Fan
Re: Mclaren MP4-31 Honda Speculation Thread
Nathanael F1 wrote:
ferkan wrote:It leaked! Ron must be pissed :lol: Looks like evolution of last years car, which means that one must have been good enough to go further down the road.
BTW is it just me or did they intentionally angle the overhead photo to exaggerate "coke bottle" area? :D Seems like they did when looking at front end of the car and then back end which appears slightly bigger in proportions.
They did the same last year.
http://www.f1fanatic.co.uk/wp-content/u ... rhead3.jpg
New MP4-31 engine cover looks wider compared to 2015 car. Air inlets are also bigger.
DarkAlman
DarkAlman
Does the rule say all turbine exit exhaust gases must "pass through" or "exit" the tailpipe?
