giantfan10 wrote:TAG wrote:It's insanity.
Not insanity... actually i love it : ) they way i see it the teams that were doing it were cheating. What else do you call a deliberate attempt to circumvent a rule?
Hmmm... I beg to differ. It's what the sport has always been about, pushing the rules until they're banned. I mean seriously what was the difference between something like this and what Red Bull was doing with their flappy front wings, basically dragging them on the ground on the long straights until the testing caught up to them a year or more later.
A couple of points though Mercedes is not the only team reportedly doing this as there's example after example of the divets and potentially hollow spokes etc, this bubbled up recently but it's been going on since October of last year. Mercedes are simply using the best implementation because they apparently coupled it with some intricate machining in the inside drum of the wheels themselves that create fins. These fins may help absorb and then dissipate the heat. From what I read years ago it's my understanding that wheels are homologated for the season to it's possible that Mercedes were the only team that found that advantage and now other teams would be unable to copy that until next season.
But here's the point, if the rumor is that this is giving Mercedes .1 tenth advantage, that's great but it's only on the first set of tires, it's useless after that. Additionally since other teams are using the same technique, they're getting what? .05 hundreds? (pure conjecture here but it's how things work in F1 so I'm comfortable with that statement) now you're looking at very minuscule gains over a race distance. I mean it's even a bit comedic when you consider the fact that Mercedes and particularly Hamilton has had such poor starts they've effectively more than thrown away tenfold any advantage gained by this.
All is well and good, take the temperature before the wheel goes on, a simple enough step. But to further increase the minimum pressure is a bit of a tit for tat and frankly it's very possible that the draconian increase in minimum pressure may be contributing to the suspension failures we're seeing this weekend.
