FW17 wrote:Can you pls explain your 900kph wheel tip assumption?
The speed of the wheel will be only 250kph considering the diameter
when it is assumed, that the tyre has no slip on the track and the car travels at 450kph you double the speed on the top surface.
This is because the contact point acts as the instant center of the rotation, the centre of the tyre moves at 450kph and the top has double the distance to the instant center of rotation. You can imagine it as an addition of an unrotating tyre moving at 450kph and a rotation, so that the contact point with the surface has no speed.
The wheel centre always moves at the same speed as the rest of car, therefore 450kph.
