2017 F1 T Wing
oetger
Re: 2017 F1 T Wing
Re: 2017 F1 T Wing
Re: 2017 F1 T Wing
Re: 2017 F1 T Wing
This is the second time Mercedes looses their T Wing in practice, i don't know how they haven't been asked to reinforce the thing... FIA was quick to do it against Haas.
FrukostScones
Re: 2017 F1 T Wing
the fins are fine (and tested ones even better), but those T-Wings can f*ck off.
analogue terrestrial TV is dead anyway.
"I ain't with the FIFA, I'm in Tokyo." LH
Re: Mercedes T Wing
godlameroso wrote:
27 Feb 2017, 00:31
I personally think it's a waste of time. There's areas that are much juicier low hanging fruit than some tiny winglet that probably adds more drag than anything else. Optimizing the rear diffuser, and floor is worth a good second by itself, as there's plenty of front downforce to balance the already plentiful rear downforce. If the T-wing is good for anything it's maybe as a way to keep the rear wing energized when following another car. Sometimes adding bits for the sake of it is counter productive, because you can get lost in trying to balance out too many aero surfaces to work together. When a more "simple" but more well thought out design can be just as good, and probably a better baseline as there's fewer variables to confound you. Which also makes development more structured and easier to validate.
Bottas doesn't seem to lose anything without a T-wing, frankly not only are they a hazard but they're also effectively useless unless their purpose is to make the cars uglier.
Phil
66
Re: 2017 F1 T Wing
Given both Mercs used their T-Wing during FP3 i guess means they are considered "safe" by whatever standards the FIA declared...
#Team44 supporter
Re: 2017 F1 T Wing
Phil wrote:
15 Apr 2017, 16:19
Mercedes did strengthen it according to Toto.
DaveW
DaveW
239
Re: 2017 F1 T Wing
Toto Wolff: Mercedes F1 T-wing could sustain hit from baseball bat.
Probably the Tacoma Narrows bridge would also survive a hit from a baseball bat!
Dipesh1995
Dipesh1995
104
Re: 2017 F1 T Wing
Interesting explanation of how the T-Wing works using CFD: https://youtu.be/yJ-xdo8Ebzg
