Rear wing flex and FIA regulatory test 2021
Hoffman900
Hoffman900
219
Re: FIA Rear Wing Test - 2021
RZS10 wrote:
12 May 2021, 19:56
Nah the only thing that would flex the wing 'upward' would be it's own weight under a few G of braking - the forces are probably near negligible compared wto the downforce.
Especially considering that the aero forces on the rider of a MotoGP bike is more than enough to overcome them hitting a peak 2g’s in braking.
Sure the F1 car does more, but the rear wing weighs a lot less than a rider plus the rider isn’t producing downforce.
Dejaeger22 wrote:
12 May 2021, 18:36
PlatinumZealot wrote:
12 May 2021, 16:03
Dejaeger22 wrote:
12 May 2021, 14:42
Yeah, but can’t you use the heat to achieve this effect?
Heat from where? Look where the exhaust pipe is and the direction of the air as it moves over the car. Pretty much impossible.
What they are doing to achieve the bending is quite simple actually. Take for example your legs. You can stand up straight and your knees wont bend. That is all 200 pounds of you or whatever you weigh. But if a friend pushes the back of your knee while you stand, it will bend easily even when under you weight. Simple mechanics.
The exhaust gases pretty much interact with the rear wing and its endplates. That’s where you get the heat energy from. I’m not saying that’s what is going on, but just an idea.
But why can’t it be replicated during static testing by the FIA? Is it something about the test itself you suggest?
Miniscule.
Whatever little heat radiation gets to the endplates is immediately counteracted by air cooling it at whatever hundred miles per hour.
If if it is heated enough it wont sag as much as it It will flop and vibrate side to side. (enplates bowing sideways).. And they will never come back..
In fact what u say is counter intuitive... No engineeeing is necessary.
Because as the car goes faster the endplate is cooled more. It would actually be softer in the corners not at the end of straights.
Stu
It looks to me as though the front edge of the rear wing is staying in roughly the same place vertically, which suggests that the bending is being achieved with the lower beam element. The wing itself is rigid (hence it passes the current tests), the new tests will load the wing differently....
That isn’t cheating, that is designing to the rules!!
Let’s hope for Mercedes sake they don’t apply load tests to the shark fin or T-wing....
Really interesting is the comparison of air box volume, but that could be a trick of the light.
RZS10
359
Do you mean the bright edge? I'd say that's just the reflection or lit area staying in the same spot with the element itself moving quite a bit. Just looking at the angle change of the endplate it's really clear that the entire wing is 'flexing' or rather tilting backwards.
Added a zoom and lines to the video which was posted previously
Hoffman900
Hoffman900
219
How does DRS vs non DRS data look from the races we’ve had so far?
One could presume DRS would have less of an effect on cars who are exploiting this the most.
You can actually see the space between the wings turning to a more open angle as the wing tilts back.
Analysts from all over the web have been talking about the steeper climb in speed the RB16B has versus its rivals as it goes into the higher gears. Could definitley be because of this wing. A sort of passive DRS.
zibby43
zibby43
Stu wrote:
12 May 2021, 20:52
What would be the advantage of the shark fin's flexibility? Or the t-wing for that matter?
Wouldn't you want a flow conditioner to be as stable as possible?
SiLo
139
RZS10 wrote:
12 May 2021, 20:57
That makes it so much more obvious, that is quite a lot of flex. Be really interesting to see if we can work out the angle of attack change and then guesstimate some l/d ratios from it.
Felipe Baby!
RZS10
359
Wonder whether it's OK to just measure the angle change of the endplate in the pic i posted here (no)
viewtopic.php?p=970735#p970735
If the answer is yes (it isn't) then it's 10° (nope)
I was actually looking for a side view of the car to draw lines from the t-cam over the tip of the sharkfin ... heh
Hoffman900
Hoffman900
219
RZS10 wrote:
12 May 2021, 22:45
If the answer is yes then it's 10°
There might be some lens distortion, so don’t forget that.
A camera pan from the end of a straightaway might be interesting.
648
Zynerji wrote:
12 May 2021, 16:02
Still looks (to me) like the top cam cover mounts to the tub are pulling away at speed, pivoting around the bottom mounts, shotgun style, leading to the wing rotating backwards at the axle centerline.
iirc Lotus used this feature in the 1968 US GP - on Graham Hill's 3rd place car (though broken it won him the WDC)
the 'new and improved' FIA test seems inadequate - using only 1000N downforce etc
aircraft designers have spent the last 100 years making wings deform favourably in angle for any and all increases in lift
cfc being as highly anisotropic as desired is particularly handy for this
PS yes to the lens distortion
RZS10
359
Yea i'm quite sure not just the lens distortion but that the perspective changes the angle to some degree (pun intended)...
Realistically it's probably around ~3°
Dejaeger22
Dejaeger22
12 May 2021, 20:28
Dejaeger22 wrote:
12 May 2021, 18:36
12 May 2021, 16:03
Miniscule.
Yeah I get your last point. I agree with you. Must be solely the FIA test than and how it is performed.
SiLo wrote:
12 May 2021, 22:26
RZS10 wrote:
12 May 2021, 20:57
Drops about an inch maybe? If the wing is two feet deep. That's about 1/24 or about 2 degrees of tilt.
SmallSoldier
SmallSoldier
481
Stu wrote:It looks to me as though the front edge of the rear wing is staying in roughly the same place vertically, which suggests that the bending is being achieved with the lower beam element. The wing itself is rigid (hence it passes the current tests), the new tests will load the wing differently....
They are not “cheating”... But is no different than when other innovations have been either banned or TD’s enacted to minimize or eliminate their impact (Mclaren’s F-Duct for example... Or Oil Burning in the Hybrid era).
