Alfa Romeo C42
Re: Alfa Romeo C40 Speculation
jjn9128 wrote:
15 Feb 2022, 13:30
f1rules wrote:
15 Feb 2022, 13:28
Rear and front push rod
They buy this from Ferrari? So points to Ferrari going the same way?!
I think they have their own gearbox this year.
Re: Alfa Romeo C42
Are they using that bump to accelerate airthat flows there, by squeezing it between the bump and the sidepod bottom?
AeroDynamic wrote:
15 Feb 2022, 14:43
timbo
timbo
113
Re: Alfa Romeo C42
This has to be a side impact structure.
DiogoBrand
74
Re: Alfa Romeo C42
The sidepods with huge undercuts and exits on top, as well as the high center front wing seem both very similar in concept to Aston.
Also, that cutout on the diffuser just besides the front of the rear wheels seems like it will be recurring for most teams.
Blackout wrote:
15 Feb 2022, 16:34
Saykas wrote:
15 Feb 2022, 16:27
https://i.imgur.com/6DFmAHs.png
Their tunnels behind the entries seem to be very low, so low that the crash structure is protruding (the bump)
Couldn't that bulge on top of the floor cause huge aero issues?
Mat-tes
Mat-tes
30
Re: Alfa Romeo C42
Are these the ventury strakes running all the way into the floor edge?
Interesting to see a similar cooling/undercut philosophy to Aston Martin with no visible heat outlet at the rear and the use of the Venetian sidepod. Everything looks just a bit rounder and less "extreme" than on the green car.
Interesting how the leading edge of the main side strake for the ventury tunnel is very rounded at the tip, so far the other two real cars show really a sharp edge there.
How teams manage the bump from the lower SIP is going to be interesting, jelly mold it or run a smoother cover over it? All of these things are really nice to see, lots of technical diversity!
Re: Alfa Romeo C42
timbo wrote:
15 Feb 2022, 16:49
That's what I said. To me, the other tunnel entries look like this (top, in this magnificent drawing / red =impact tube) while Alfa is like the bottom one
AeroDynamic
349
Re: Alfa Romeo C42
Blackout wrote:
15 Feb 2022, 14:31
There is strange concave shape (concave tunnel leading edge) behind the bottom wishbones in that front view...
Blackout wrote:
15 Feb 2022, 16:47
https://i.imgur.com/zyONIq8.png
jjn9128
779
Re: Alfa Romeo C42
AeroDynamic wrote:
15 Feb 2022, 17:30
https://i.imgur.com/JdVKB3R.jpg
https://i.imgur.com/hIRR4QF.jpg
https://i.imgur.com/hqWbVgX.jpg
Blackout wrote:
15 Feb 2022, 14:31
Blackout wrote:
15 Feb 2022, 16:47
Sort of McLaren-esque but not quite
#aerogandalf
AeroDynamic
349
Re: Alfa Romeo C42
Floor Detail on trailing egde
Roll Hoop..
Giando
93
Re: Alfa Romeo C42
It would be a very strange position for the lower side-crash cone... it seems way too low... isn't it?
michl420
michl420
Re: Alfa Romeo C42
Giando wrote:
15 Feb 2022, 17:40
Min. high is 100mm from the reference plan per regulation.
Zynerji
111
Re: Alfa Romeo C42
Are these the first "non standard" wheel canard/blade that we've seen? I don't recall the others having splits in theirs.
AeroDynamic
349
Re: Alfa Romeo C42
How Alfa’s shock F1 test reveals the most 2022 design secrets yet
Alfa Romeo’s C42 Formula 1 car for 2022 has broken cover early, after oddly setting a launch date after the first Barcelona test, and its first run at Fiorano has revealed some intriguing design secrets despite a camouflaged livery.
Matt SomerfieldFeb 15, 2022, 4:00 PM
The front wing appears to be more like the final spec that you’d expect to see in testing than what we’ve already seen from other teams.
Alfa has opted for a very unloaded outer section once again, having been the team that ran the most aggressive iteration when the regulations were changed in 2019.
Click Here to continue reading article.
Marty_Y
Marty_Y
Re: Alfa Romeo C42
Zynerji wrote:
15 Feb 2022, 18:24
I'm probably wrong but I think they all have had it, someone said in another thread that it's a standard part.
AeroDynamic
349
Re: Alfa Romeo C42
