All I will say to this is amateur race orgs need volunteers and clearly you are all a passionate bunch with time on your hands.
Maybe volunteer and work towards becoming a steward / race director in real life and not a forum?
Honestly, I don't think the FIA or Liberty would accept stewards who rigidly adhere to the rules. We'd see a lot more black flags, and post race DSQs, and that just wouldn't be palatable to the casual fan base just looking for drama, and thus not good for business.Hoffman900 wrote: ↑09 Mar 2022, 18:08All I will say to this is amateur race orgs need volunteers and clearly you are all a passionate bunch with time on your hands.
I agree 100%, but my point still stands. Racing on the amateur level can only happen if people volunteer. Better to do it in real life than an internet forum.dans79 wrote: ↑09 Mar 2022, 19:30Honestly, I don't think the FIA or Liberty would accept stewards who rigidly adhere to the rules. We'd see a lot more black flags, and post race DSQs, and that just wouldn't be palatable to the casual fan base just looking for drama, and thus not good for business.Hoffman900 wrote: ↑09 Mar 2022, 18:08All I will say to this is amateur race orgs need volunteers and clearly you are all a passionate bunch with time on your hands.
I literally said they are not fully accurate, they show the difference between Verstappen and Massa quite well, but like a good troll you still have to argue about that, there is no good way to draw a line down the center of the car from the onboard of another car.PlatinumZealot wrote: ↑09 Mar 2022, 16:18Oleo wrote: ↑07 Mar 2022, 21:30Pretty much this:
Difference is Massa left no space inside, Max did. And in Silvertone Lewis missed the apex.
There is no space for 1 car on the inside of Massa's line, Verstappen clearly does leave space (disclaimer: red lines may not be 100% accurate, so dont nitpick on it, the difference if obvious and clear):NathanOlder wrote: ↑07 Mar 2022, 12:51
Well the 2 photos I posted show that both times at the point of contact, there was space on the inside and neither of the incidents had even reached the apex.
https://i.imgur.com/dzarUVG.jpg
https://i.imgur.com/4XLf32m.jpg
2011 is probably a racing incident or small penalty for Massa. Hamilton makes a move that does not really fit in that corner, having to slow his car more due to a bad corner attack angle, Massa cuts his opponent off and does not leave enough space, possibly due to not seeing him properly or assuming the other guy will back out due to having that bad angle.
2021 is clearly mostly the fault of Hamilton. Verstappen is somewhat enthousiastically taking the outside line, but leaves more than enough space for his opponent. Hamilton takes too much speed into the corner and cannot hold the inside line, hitting his opponent on the back wheel.
1) The red lines you put there are not consistent. To show where the car is pointing, all you had to do is draw a straight line down the center of the nose of the car. Then...
2) Use the steering lock and speed of the car to estimate a curve to show the path of the cars.
In both cases, Lewis is not on the apex. In Silverstone he actually had more steering angle towards the Apex.
So your conclusion for 2021 is not logical.
You can just watch his onboard and the topview instead of trolling. I did not say his trajectory would not be altered, it in fact was not affected much.Just_a_fan wrote: ↑08 Mar 2022, 23:25That is after the contact. To say that Hamilton's trajectory wouldn't be altered by the contact is disingenuous.Oleo wrote: ↑08 Mar 2022, 21:36Observable fact, missed apex:Just_a_fan wrote: ↑07 Mar 2022, 22:20
At Silverstone they hadn't even arrived at the apex before the contact. He missed it because it was still well ahead of him. You can see it in the picture. It's on that red and white kerbing ahead of him.
It's ok having a view but at least make it consistent with the observable facts.
He was over the white line and only managed that by dropping a ton of speed, hence ending up behind Leclerc. Watch the video instead of trolling.dans79 wrote: ↑08 Mar 2022, 21:44I'm not sure if you are aware or not, but any car in the position will lose a lot of downforce because of the outwash from the other car will disturb the flow over its aero surfaces.
And in spite of the contact and loss of aero downforce he still made the corner!
Not to mention the car does not instantaneously go back to full downforce/settle after driving through dirty air, or after contact!
Trollolol. You ve never driven a car? At literally every point of every corner you will ever make your car will be pointing towards a wall, lamppost, sidewalk, pedestrian or whatever is next to the road. The lines are an indication where the car is pointing at that point of time, not an expected driving line, showing Verstappen leaving room on the inside, while Massa is already aiming at/near apex, thus closing the door. OP asked for the difference in the situation, the most obvious one is the room given by the outside driver, which is indicated by the direction the car is travelling at point of contact, shown by the redline.AeroDynamic wrote: ↑09 Mar 2022, 17:40so based on that red line, Max was going into the wall without help?
Per the rules you are considered on track as long as at least on of your wheels is touching the white line, how you achieve that is irrelevant!
Oleo is just accusing others of trolling, best temper your involvement accordingly.PlatinumZealot wrote: ↑09 Mar 2022, 20:41Oleo needs to analyse the other car. Very one sided analysis.
Get the onboards of the other car, Oleo.
At the exit of Copse, the kerb was considered the race track. I remember seeing it in the notes, so the race track is infact even wider than the white line there. Lewis stayed on track the whole time.
I think that seems fairly accurate, and think the penalty was harsh for Lewis, and very harsh for Massa in India. Both the cars on the outside were aggressive with their closing of the door and they both paid a heavier penalty in the incident itself.101FlyingDutchman wrote: ↑10 Mar 2022, 02:02Let’s start by saying both drivers knew exactly what they were doing. Based on previous incursions, Max assumed Lewis would avoid the contact as he had done. Lewis “could” have avoided it but decided that enough was enough and kept it firmly planted
Stewards decision was pretty much correct. Racing incident with Lewis predominately at fault for causing the collision as he had the ability to avoid it. But nonetheless Max also had no business to close the door that directly. Can we move on?
The lobbying from RBR is why there was the harsh penalty.NathanOlder wrote: ↑10 Mar 2022, 10:01I think that seems fairly accurate, and think the penalty was harsh for Lewis, and very harsh for Massa in India. Both the cars on the outside were aggressive with their closing of the door and they both paid a heavier penalty in the incident itself.101FlyingDutchman wrote: ↑10 Mar 2022, 02:02Let’s start by saying both drivers knew exactly what they were doing. Based on previous incursions, Max assumed Lewis would avoid the contact as he had done. Lewis “could” have avoided it but decided that enough was enough and kept it firmly planted
I would call both racing incidents.
Anyone can hear on Lewis' onboard that he was off the throttle backing out of it.101FlyingDutchman wrote: ↑10 Mar 2022, 02:02Let’s start by saying both drivers knew exactly what they were doing. Based on previous incursions, Max assumed Lewis would avoid the contact as he had done. Lewis “could” have avoided it but decided that enough was enough and kept it firmly planted
