2026 F1 Cars - General Thread
470
Re: 2026 F1 Cars - General Thread
mzso wrote:
02 Jul 2023, 08:45
This could be a major save I suspect. They can remove around a meter and a half of "stuff. Not sure why the obsession with wheelbase in the regs and elsewhere. Just impose a hard limit of 4.3 meters for the car and they can move around the wheels within that the way they please.
What was the last car to be 4.3m or less?
The McLaren MP4/4 was 4.4m long.
The Ferrari 312T4 was 4.46m long.
mclaren111 wrote:
06 Jul 2023, 10:31
What are the moveable aero parts they're talking about ?
So far, flaps on front and rear wings are mentioned. Could be beam wings in the end as well.
Holm86
249
Vanja #66 wrote:
06 Jul 2023, 10:47
mclaren111 wrote:
06 Jul 2023, 10:31
Which definitely will increase the weight even more
mzso
mzso
65
wuzak wrote:
06 Jul 2023, 10:44
mzso wrote:
02 Jul 2023, 08:45
Can't say without data. But for a long while it hovered around 4.3-4.4
bagajohny
bagajohny
https://www.auto-motor-und-sport.de/for ... rodynamik/
Any thoughts? I think I agree with Horner on this one.
470
bagajohny wrote:
13 Jul 2023, 17:03
You may have to put some quotes, because most of the article requires a subscription.
bagajohny
bagajohny
wuzak wrote:
13 Jul 2023, 19:03
bagajohny wrote:
13 Jul 2023, 17:03
This user has posted the whole translation.
JordanMugen
86
wuzak wrote:
21 Jun 2023, 19:02
They have talked previously about making the cars smaller.
I would be surprised if they make them any smaller than an F2 car, though a move to F2 dimensions (1.9m width and 5.2m length) and F2 tyres (i.e., the old 2016 sizes but with 725mm overall diameter) would be sensible and not make too much difference IMO.
mzso wrote:
06 Jul 2023, 12:13
In the 1980's with driver's feet in front of the front axle? This seems unrealistic when this is no longer allowed and when an F2 car is now 5.2m long and already looks much smaller than an F1 car.
bagajohny wrote:
13 Jul 2023, 17:03
Horner's always playing the political game to benefit his team. He's relentless and very good at it, which is all good honestly, other TPs should step up their own game :)
In this case, there aren't any definitive bodywork rules, so there are no aero rules or guidelines either. It's impossible to objectively make the conclusions he and Max said RB made of the new rules, so it's hard to see it as anything but pressure towards FIA to extend the rule set that's beneficial for them and delay the rule set that will undoubtedly cause them loads of trouble on PU side.
470
Vanja #66 wrote:
16 Jul 2023, 16:23
In this case, based on what Pat Symonds has said, it would seem that the FIA have sent the teams preliminary data on on the 2026 rules, though Symonds also said that the teams have data that is 6 months old.
That may seem to suggest that the FIA engineering team have struggled to get a set of rules that work with the 2026 PU and deliver lap time similar to currently.
My thought is that it will be terrible.
Current cars accelerate most of the straights, only the last little bit do they slow down when the ES is depleted and/or they start sending power from the ERS to the ES.
For 2026 they will probably reach top speed in the first 1/3 of a straight and then maintain the speed or get slower as they travel along the straight.
That's not even thinking about high speed corners that will, probably, require significant input from the MGUK.
wuzak wrote:
16 Jul 2023, 18:33
Wolff, Szafnauer and Vasseur made comments about those statements from Horner immediately, saying that those comments were premature. You won't find 3 TPs from 3 different PU makers making exact same comments unless it's true. :)
As for electrification overall, it started way back in 2009 and early adopters were hindered. Many things are quite common today that were considered crazy 10-15 years ago. That's always the case with technical rule change in F1 :)
Cs98
Cs98
37
Vanja #66 wrote:
16 Jul 2023, 16:23
Cynicism to the point of looking past basic facts. There will be no delaying of the 2026 rules, all parties involved are clear on this and it has never been suggested in the first place. Horner is talking about tweaking fuel flow to make the 2026 ICEs slightly more powerful.
On the "trouble" part. These engines are not particularly complicated (at least compared to what we have now), they're just weak, and lacking in regeneration.
Cs98 wrote:
16 Jul 2023, 20:46
What cynicism? Horner literally went all out with his first statement and urged for a rethink of the rules, as you said. What's wrong with understanding there's (always) an agenda behind that :lol: Wolff criticised 2017 and 2022 rules a lot, for the same reason
saviour stivala
saviour stivala
Cs98 wrote:
16 Jul 2023, 20:46
Vanja #66 wrote:
16 Jul 2023, 16:23
Horner was not talking about tweaking the fuel flow, he was talking about tweaking the two power split.
Vanja #66 wrote:
06 Jul 2023, 10:47
mclaren111 wrote:
06 Jul 2023, 10:31
I would be surprised if beam wing is included. Currently the beam wing is a structural element. It carries the load of the rear wing.
A lion must kill its prey.
