Seems like a lawyer entered the conversation
Correct. What exactly is George's red flag in Brazil qualifying and the events around it add to the "2023 Pecking Order" topic?
you need to read back people where talking about rivalry in 2023 using 2022 as reference point ,implying that it will continue that how last year was bought in conversation.
Given their history it is an easy argument to make in their favour....buuuuuut....they got these years regs wrong (by their standards) which means they are in a knowledge deficit to RB and SF.TimW wrote: ↑01 Jan 2023, 22:07Yet you have faith in AM to overcome as much (or more) of a deficit to McLarenSisyphus_1 wrote: ↑31 Dec 2022, 23:46Lots of faith in Mercedes from many posters.
...If they do it they deserve to be crowned kings of the milkyway galaxy, but it's doubtful.
I'm going to go with:
1. RB
2. SF
3. MB
4.Alpine
5. AM
6. Mclaren
In the end the RB performance is the result of the first year of development. I don't see how Mercedes with their very strong team, sufficient pictures of the RB with all details to analyze and a second year of development with a wind tunnel time advantage would not be able to catch up. Not saying they will, but they definitely could (should?).
Alternately, if RBR got their package right 'straight out of the box' there is not going to be as much easy pickings as one that missed by a mile. Providing of course they know where the problem lies.Sisyphus_1 wrote: ↑04 Jan 2023, 20:52Given their history it is an easy argument to make in their favour....buuuuuut....they got these years regs wrong (by their standards) which means they are in a knowledge deficit to RB and SF.TimW wrote: ↑01 Jan 2023, 22:07Yet you have faith in AM to overcome as much (or more) of a deficit to McLarenSisyphus_1 wrote: ↑31 Dec 2022, 23:46Lots of faith in Mercedes from many posters.
1. RB
2. SF
3. MB
4.Alpine
5. AM
6. Mclaren
As RB and SF had great packages from race 1, they only need to refine.
The slower teams have much lower hanging fruit than the bigger teams.TimW wrote: ↑01 Jan 2023, 22:07Yet you have faith in AM to overcome as much (or more) of a deficit to McLarenSisyphus_1 wrote: ↑31 Dec 2022, 23:46Lots of faith in Mercedes from many posters.
1. RB
2. SF
3. MB
4.Alpine
5. AM
6. Mclaren
Would running higher initially not lessen the effects of the 2023 rule changes? If the floor is raised higher at the rear, then the RB was already running with rake and pretty high at the rear compared to others.PlatinumZealot wrote: ↑22 Jan 2023, 23:58The technical regs can go one of two ways.
The raised floor ruling can snip RedBull's advantage of using higher rake coupled with articulate suspension and awesome vortex sealing....
Or...
It could pay even more dividends for RedBull's mastery of sealing higher ride-height floors!!
The pecking order is a very tough call this year.
I'm getting a sense that McLaren will finally fight in the top ranks for some reason..
There is no doubt that running the car closer to the ground generates more DF. No team ran higher ride height in 2022 to increase DF. It was usually done to prevent the car or drivers from disintegrating from the porpoising. When they were running flat out in a corner, all the cars were as close to the ground as possible with little to no rake.chrisc90 wrote: ↑23 Jan 2023, 00:06Would running higher initially not lessen the effects of the 2023 rule changes? If the floor is raised higher at the rear, then the RB was already running with rake and pretty high at the rear compared to others.PlatinumZealot wrote: ↑22 Jan 2023, 23:58The technical regs can go one of two ways.
Or...
What about the static ride height though? Where the measurements for parc ferme are taken? Surely if you can have a higher static ride height to pass the tests, but your car then runs close to the ground when driven then surely its an advantage?diffuser wrote: ↑23 Jan 2023, 00:37There is no doubt that running the car closer to the ground generates more DF. No team ran higher ride height in 2022 to increase DF. It was usually done to prevent the car or drivers from disintegrating from the porpoising. When they were running flat out in a corner, all the cars were as close to the ground as possible with little to no rake.chrisc90 wrote: ↑23 Jan 2023, 00:06Would running higher initially not lessen the effects of the 2023 rule changes? If the floor is raised higher at the rear, then the RB was already running with rake and pretty high at the rear compared to others.PlatinumZealot wrote: ↑22 Jan 2023, 23:58The technical regs can go one of two ways.
Or...
From what I understand, how far down the outer floor edge can come down is measured from the plank. Whatever the height that the floor edge had to be above the plank in 2022, they added 15mm for 2023. So if you want to get closer to the ground, you need pull up the plank.chrisc90 wrote: ↑23 Jan 2023, 00:40What about the static ride height though? Where the measurements for parc ferme are taken? Surely if you can have a higher static ride height to pass the tests, but your car then runs close to the ground when driven then surely its an advantage?diffuser wrote: ↑23 Jan 2023, 00:37There is no doubt that running the car closer to the ground generates more DF. No team ran higher ride height in 2022 to increase DF. It was usually done to prevent the car or drivers from disintegrating from the porpoising. When they were running flat out in a corner, all the cars were as close to the ground as possible with little to no rake.
To avoid porpoising, Mercedes has to run higher. While the best performance of their car is running lower, but then it starts it's disco at that state. So by having forced these regulations, other teams also now have raised floor edges and diffuser opening now, by which they lose downforce and potentially go on par with Mercedes, who anyway have to raise to keep sanity of the car and drivers.Chuckjr wrote: ↑23 Jan 2023, 21:10Maybe someone here can help me understand why since the new regs require a rear lift the Merc supposedly is advantaged when Merc have said repeatedly they need their car planted on the ground to get the most out of their concept. Why is Merc the most advantaged when RB in fact runs a high static height already? All cars are basically on the ground in the corners.
Honest question.
During the season this a bigger issue to overcome but they seemed to have gotten car under control by the end of the year. So those learnings were fed into the new car design. It all comes down to what the find in the wind tunnel.Chuckjr wrote: ↑23 Jan 2023, 21:10Maybe someone here can help me understand why since the new regs require a rear lift the Merc supposedly is advantaged when Merc have said repeatedly they need their car planted on the ground to get the most out of their concept. Why is Merc the most advantaged when RB in fact runs a high static height already? All cars are basically on the ground in the corners.
Honest question.
