Red Bull suspects McLaren and a few other teams of filling water into the tyres
TimW
TimW
36
Re: Red Bull suspects McLaren and a few other teams of filling water into the tyres
SilviuAgo wrote:
03 Nov 2024, 14:50
Gary Anderson: Red Bull's McLaren tyre water theory doesn't add up
https://www.the-race.com/formula-1/red- ... -anderson/
That article is utter nonsense, apparently someone missed a few physics classes. At 80 degree the vapor pressure of water is 0.5 bar, so the partial pressure of water in the humid air would be 0.5 bar! I don't know the exact density of water vapour at 80 degree, but something like 0.8g/ liter would this mean 0.4 gr/liter tire internal volume would evaporate.
The boiling point of water is of little relevance in a closed system. If there is liquid water, it will just be in equilibrium with the air above, and the air will reach 100% humidity. No sudden transition at 100degC, just a gradual rise in pressure.
SilviuAgo wrote:
03 Nov 2024, 14:50
Gary should stay far away from thermodynamics, heat and mass transfer topics. Not his strong point.
The tyres are about 20 psi so the evaparation rate would be a bit lower, however he has no business talking about boiling point! :lol: Boiling point is temperature when the vapour pressure above the liquid is at envrionmental pressure and would be nothing like 100*C in that tyre, Pretty much the whole tyre would need a substantial amount of water for that, and that is beside the point too. The water does NOT need to boil to evaporate! It's just a problem of evaporation ( or mass transfer) inside the tyre.
Heating the water causes more vibrations of the molecules at the surface raising the vapour pressure, and then that will try to equilibrate with the partial pressure of water vapour in the air, spreading more vapour around (an also creating an evaporative cooling effect). The tyre can basically be cooling pipe like what you see in computers.
TimW wrote:
03 Nov 2024, 15:07
SilviuAgo wrote:
03 Nov 2024, 14:50
Ah thank you! We posted the same time with similar points! Boiling point has little to do with this. Gary is just good at churning out articles to meet some sort of deadline imposed on him!
TimW wrote:
03 Nov 2024, 15:07
SilviuAgo wrote:
03 Nov 2024, 14:50
Haven't seen a good article from Gary, unless he's months late to some explanation, since forever...
TimW
TimW
36
EDIT: Ok, this was nonsense, I misinterpreted the graph
Heat transfer increases dramatically with humidity:
https://www.researchgate.net/profile/Ka ... rature.png
So there is a huge benefit of you need heat transfer between tire and rim.
As long as you make sure that all water evaporates, I don't think there is any big impact on the thermal expansion coefficient.
So to me there seems to be a clear possible gain here, if you can sneak in a few cc. of water in while adjusting the tire pressure.
My biggest reservation is that this would be an outright violation of the rules, not a grey area. Just like adjusting the bib height in parc ferme would be. I'd expect a team to be taken out of the constructors standings as a penalty for that, if caught. And I cannot imagine a team taking that risk.
avantman
avantman
TimW wrote:
03 Nov 2024, 16:11
Not gonna happen in this time an era. Mosley was the last FIA president that had big enough balls to do that. And which is why they had him destroyed.
TimW wrote:
03 Nov 2024, 16:11
Could you imagine the team violating the technical regulations with regards to the limit on fuel flow, got caught, but kept all their points in WCC. I possibly couldn't ten years before, but not now.
This thing is business first, show second, sport fourth. Not to mention the inner politics. No shareholder, including rival teams would like to create another huge scandal. And team exclusion from WCC would be a huge scandal. The integrity of the sport would get questioned again. This would be very harmful to the whole F1 business directly. Modern FIA presidents are fully controlled puppets that only pretend to be fully independent entity .
Stea1th
Stea1th
Merc in trouble currently for tire pressure change
PapayaFan481
PapayaFan481
Vanja #66 wrote:
03 Nov 2024, 15:15
TimW wrote:
03 Nov 2024, 15:07
SilviuAgo wrote:
03 Nov 2024, 14:50
Finally something you and I can agree on!!
The Race need to get a better, more recent, Technical Expert, because Gary has been so long out of the sport and rarely gets things right.
If I come across as blunt, I apologise, it's my ASD. Sometimes, like an F1 car aqua-planing, it gets out of my control.
From The Race
"Red Bull feels the performance of certain teams in the Brazil sprint race vindicated its suspicions [about water injection] as it believes its race pace was stronger than it has been for several grands prix and thinks others were struggling more."
dialtone
dialtone
121
04 Nov 2024, 00:31
From The Race
you can say that about races after the asymmetric brake, bib and so on...
dialtone wrote:
04 Nov 2024, 00:32
04 Nov 2024, 00:31
From The Race
Indeed. I'm just posting what red bull thinks
Here's the article https://www.the-race.com/formula-1/fres ... ing%20more.
If red bull has race winning pace in the remaining 3 races (4 including Brazil/Brazil sprint) after not having it for a long time then it's pretty good confirmation?
dialtone
dialtone
121
04 Nov 2024, 00:33
I don't think so. Max won the Austin sprint easily and always qualified very well. The difference between cars has been minimal and down to having wrong setup and slightly sub optimal mix of corners in races.
The idea that somehow the start of year RB-20, that had Perez finish 2nd on the regular, somehow turned into a mid field car that only god emperor max could drive to a decent result was never true. RB-20 is another great car, when you are off a bit in setup it doesn't perform as well. For reasons that the team appears to not know (yeah sure), they went from a huge pace advantage at start of season to a smaller one compared to any other team.
Last I'm getting bombarded by all sorts of things now... is Max the best ever and won because he's great and as usual won despite having the worst car on the grid or is it MCL that now got robbed of their cheat and nerfed enough that now max can finally beat them?
Rikhart
Rikhart
19
dialtone wrote:
04 Nov 2024, 00:32
04 Nov 2024, 00:31
From The Race
Yes, this was a race, and it was after all that (which is mostly all bullshit as agreed by people who really hate the team and it's drivers). Did you miss the race?
Waz
Waz
SilviuAgo wrote:
03 Nov 2024, 14:50
He really makes it hard to believe that he is an engineer. That article comes as across as poorly educated or researched.
He doesn't even account that the boiling point increases with the pressure increase inside the tires. That's basic science that you learn in early high school in some places.
It's not difficult to make an assumption it's about preventing over heating, and that a small amount of water coated on the inside of the tread through centrifugal force would be helpful.
It's just blatantly stupid to claim that it's not possible or highly improbable when this very thing was specifically banned by the FIA because a team was experimenting with it years ago.
Luscion
Luscion
99
Pirelli boss Isola talking about it
https://formu1a.uno/en/f1-tyre-moisture ... nterlagos/
“There was a discussion also on special gasses,” he said. “Someone said they are changing the gas into the tyre to better control pressure. And then someone started to talk about moisture in the tyre, why we should have more or less.
“We supply the tyres with dry air inside. We have a drier connected to our system, and they get all the tyres with dry air, as in the regulation.
Isola noted that adding moisture would not be difficult.
“To do that is very easy,” he said. “You put water inside the tyre, and it’s finished. You have a valve, you put water inside. How the system works is a different story.
“It’s basically a thermal effect, heat transfer between the tyres and the rim that should give more consistency or less degradation to the tyre, even if you have worse control of the pressure.
“Because obviously, if you have vapour or steam inside the tyre, you lose the control of the pressure. You have a pressure that is higher.”
