xpensive wrote:Just out of curiosity JT, how do you figure that torque number (100-200 ft-lb) and resulting preload?
And could you please identify "soft" in engineering terms, and how Aluminium would be "annihilated"?
Actually I take that back. 250+ ft-lbf would be my guess for wheel nut torque, based on another professional open wheel design.
Axial preload is roughly F = T/K/d (roughly since K varies so much). Let's assume T is indeed 3000 in-lbf.. K ~= 0.2, d = 2". 7500 lbf of preload. Non trivial!
Regarding aluminum, it's hardness doesn't even register on the Rockwell C scale. You can coat it with something hard, like aluminum oxide (anodize) but that doesn't change the fact that it's super soft underneath. Additionally you can get wrought alloys with ~90+ ksi tensile, but it just doesn't take abuse. I'd think the impact gun would tear those fins to pieces. Casting alloys I might add are typically much weaker than wrought.
And even if it were coated, once it starts to wear off a bit you're screwed. Aluminum galls very easily (since it is so soft) and would totally seize up the thread. Totally kill your race result. Too big of a risk.
There's a reason why aluminum threads are not popular in general. You can use them in some applications, even on some racecars, but no way I'd use it professionally or on an F1 car. Way too much risk for negligible gain. Like I said you could probably do it with Ti if its disposable, and PVD coated. Alloy Ti is I think ~40 RockC? Not terrible. But you can get alloy steel up in the 55+ range.
