ringo wrote:Hey, for a while there i thought the rear end was aluminum!
It's pretty shiny.
However, the body does not look as developed as the others, hopefully i am wrong.
There is nothing on the body that really stands out, that sets this apart from the competition but then again i felt the same about the BRAWN last year.
More often than not, the cleanest simplest solution on a fast moving body is the best solution.
Each time you try to get air to change direction it creates turbulence and associated drag.
Remember the designer want to feed as much air as possible to the downfroce producing elements but in as clean flwoing stream as possible. Twists and turns just makes twist and twirly air flow which is not good.
I am very impressed with the clean lines in the Mercedes and the brushed aluminium effect makes it look like a Focke Wulf with the Red Baron at the helm!
(yes yes two different era's blah blah blah...)
