I dont see it as funny.
Of course it could be nothing but worth noteing.
Same as the Ferrari miss fire in their promo run that was never explained.
I think I know the difference having worked most my life in auto racing, you tend to notice the little things. Specifically I paid attention to the sound of the motor when it was off throttle...tonally it's a different sound than during the race at Valencia, from Webber's car in both cases. Leads me to believe what Scarb's is suggesting, about retarded timing.mep wrote:hahahahahahahaI did pay attention to qualifying today, especially the off throttle of the Red Bull in car camera. There is definitely a tonal difference of the engine in off throttle.
You really impress me, you hear a difference between on and of throttle.
I agree with Scarbs on the mapping issue being relevant but I disagree on how it is done. This can't legally be an issue of programming but rather an issue of selecting and uploading the suitable multi dimensional maps. The CAN bus is seriously fast. I have no doubt they can manage to upload those few kb in real time from the steering wheel CPU.Scarb's blog wrote:If the overheating issues can be contained, this would be a relatively simple mapping to introduce for another EBD team. As mentioned Renault Sport, Red Bulls engine supplier would have to know about this. Copying the concept, but not the actual SECU code would be quite easy.
The SECU has already a prescribed amount of maps available. Can't add to it. They wouldn't be a reason to send a map from the dash to the ECU, as maps can be stored in the ECU and are automatically selected according to conditions being met without any input from the driver. Turning those conditions on and off, is a simple press of a button or selector on a dial.WhiteBlue wrote:I agree with Scarbs on the mapping issue being relevant but I disagree on how it is done. This can't legally be an issue of programming but rather an issue of selecting and uploading the suitable multi dimensional maps. The CAN bus is seriously fast. I have no doubt they can manage to upload those few kb in real time from the steering wheel CPU.Scarb's blog wrote:If the overheating issues can be contained, this would be a relatively simple mapping to introduce for another EBD team. As mentioned Renault Sport, Red Bulls engine supplier would have to know about this. Copying the concept, but not the actual SECU code would be quite easy.
The other more interesting issue here is the question of caloric management. People disagree whether the intake injectors are actually dialed back or rather increased. I tend to think that retarding ignition and reducing fuel flow would be optimal but I don't have the necessary contacts into F1 racing to find out.
Thanks, that makes perfect sense. The point that I wanted to make is the difference between the maps and the program. By definition teams cannot be able to make changes to the program of the SECU. They should only be able to make an application to the administrator of the SECU program if they need another functionality. The program administrator should then consider such a request against legality and only implement an upgrade if it is approved by the FiA.speedsense wrote:The SECU has already a prescribed amount of maps available. Can't add to it. They wouldn't be a reason to send a map from the dash to the ECU, as maps can be stored in the ECU and are automatically selected according to conditions being met without any input from the driver. Turning those conditions on and off, is a simple press of a button or selector on a dial.
If I remember right and if it was reported correctly, it was Microsoft that wrote the GUI/controller software, replacing Mclaren's controller software, so it's doubtful that there's inactive program functional parts. More than likely the FIA prescribed exactly which functions would be allowed and which won't. Certainly hacking the program would have been a consideration of the FIA. Which is a laugh in certain ways, as Microsoft is one of the most hacked software's in the World.WhiteBlue wrote:Thanks, that makes perfect sense. The point that I wanted to make is the difference between the maps and the program. By definition teams cannot be able to make changes to the program of the SECU. They should only be able to make an application to the administrator of the SECU program if they need another functionality. The program administrator should then consider such a request against legality and only implement an upgrade if it is approved by the FiA.speedsense wrote:The SECU has already a prescribed amount of maps available. Can't add to it. They wouldn't be a reason to send a map from the dash to the ECU, as maps can be stored in the ECU and are automatically selected according to conditions being met without any input from the driver. Turning those conditions on and off, is a simple press of a button or selector on a dial.
The teams on the other hand should be perfectly able to trigger inactive program functionalities which they may wish to utilize, load different maps or switch between alternative maps that have previously been uploaded.
The SECU program offers the activation of several alternative and different maps by command of the driver. The sequential parallel shifting of gears together with the engine map is a good example for this. It allows the teams to have a particularly optimized map for each gear.gcdugas wrote:How does the Renault engine have this special engine map that allows retarded ignition over-run when they use the standard ECU?
Is that serious?Shaddock wrote:Redbull have their special engine map for Quali, that they can't really use in the race. This may make them untouchable in Q3 for the rest of the season on any track that has a couple of high speed bends.
Mclaren need to start redesigning their manifold, with the possibility of dropping a fuel injector (rules allowing) on the runners to give the car balance off throttle.
The major problem seems to have been heat on the diffuser causing it to distort in shape and not suspension heat related. This should be easier to fix than having to move/relocate wishbones.
Let's say it's 'blue sky thinking'CMSMJ1 wrote:Is that serious?Shaddock wrote:Redbull have their special engine map for Quali, that they can't really use in the race. This may make them untouchable in Q3 for the rest of the season on any track that has a couple of high speed bends.
managed engine braking etc is all fair and well, but fitting fuel injectors downstream of engine is not a serious thought by you is it?
Heat only rises in air/fluids due to convection,which is only an issue whilst stationary on the grid or for 5 seconds during a pitstop.autogyro wrote:Heat rises and the push suspension on the McLaren looks vulnerable to tranfering heat to the dampers as well as distorting the floor.
Without such a clean aero rear end as the RB, or low mounted dampers etc, it will be a far bigger problem of heat for Macca when sorting the EBD.
I did predict the heat problem as being more acute on the Ferraris but aside from their driver problems (which could be partly balance problems) it looks to have effected the Macca more.
