but you sacrifice a lot in terms degree of freedom in posiioning of pushrod ,as well as the inevitable stone and debris collecting at the bottom...=caliper not a good idea ..and the caliper with its hot pads ..cooking the bearings neatly from below at a standstill ...and bleeding the calipers is also surely not nice ...shamikaze wrote:I have always failed to understand why the brake-callipers are mounted the way they are on most F1 cars.
Last year, BrawnGP had them on the bottom of the brake-disc as well, and this year they seem to have repositioned them back. It was actually one of "the" things I looked for during the presentations of the cars in the winter.
I would think the benefist would be 3-fold:
* Lower overall CoG + lower CoG of unsprung-mass, which counts extra + centrifugal forces being placed lower to the group which I could image would aid in grip levels.
* Better aerodynamic placement for cooling purposes
GReetz,
S.
then there was the new regulation you must use aluminium as upright material now ,so the Cof G benefit is reduced quite a bit with the new regs...
