Fair enough, my bad for the off topic thing. Did you weigh the cars and the tires with and without marbles to determine if they are legal or not? Any figures that can corroborate your theory?richard_leeds wrote:This is a thread about legality not flexing wings, read the title!bot6 wrote:How is tire wear relevant to a conversation about front wings breaching a specific aerodynamic rule? Please stay on topic.
Whether you like it or not, legality is determined by tests applied to the car in the scrutineers garage. Picking up marbles is just another example of cars potentially being illegal on track (underweight) but not in the garage (with marbles).
then by your definition, suspension is illegal ?? (which would confirm the thread title)bot6 wrote: It forbids attempts to bridge the gap. Again, read the rules please.
as did it to copy the F-Duct, EBD, DDD etc., it´s the daily life of F1bot6 wrote: Work hours, prototypes and numerical simulation all cost money. These are all needed to design, dimension and develop such a device.
The key is consistency. Every team knows how the rules are being applied.bot6 wrote:My problem is with the FIA selectively applying their rules. It's not the first time and it unfortunately won't be the last. But here, it's especially blatant and it aggravates me.
If the red bull wing is illegal, they all are. They all flex to a degree;they're all at minimum height so any flexing goes too low. The Mclaren wing was awful flexi in melbourne also.bot6 wrote:Well, again, it all depends which team you're rooting for (if you're rooting for one at all).
The regulatory framework says the RBR wing is illegal. But the person in charge of applying the regulatory framework says it is legal.
Honestly, for me the whole thing isn't about RBR being dishonest. I think they saw this coming last year and are exploiting it as much as possible, and if the FIA doesn't react then that's good points in for RBR and good for them.
But I do think this contradiction between the rule and the application hurts the credibility of the FIA and hurts the credibility of Formula 1 racing as a result. Either the governing body needs to be changed, or the governing body needs to rewrite the rule book in a way that is clear and even for everybody.
And not just that FW rule. The whole bloody rulebook.
1-1.5 seconds per lap advantage over a device which is illegal but allowed is a bit of a mockery of racing in my opinion...
sure, and does the suspension, or more precisely the spring in the former, helps to "attempt to bridge the gap" between the sprung part of the car (for example the skidblock/plank or the front wing) and the ground?bot6 wrote: 747heavy -> Rule 3.15 applies to the sprung part of the car. How is suspension part of the sprung part of the car? It's the springing part, not the sprung part.
It is perfectly clear that the rule is being enforced using the flexing test.bot6 wrote:See Richard, I don't get how it can be clear ahead of the season that a rule will not be enforced.
"any circumstance" also applies to the item about bodywork not being below the ref plane. I expect all teams fail that too.bot6 wrote:Then there is the matter of rule 3.15, which applies differently from the others because of the magic words "under any circumstances". That means this rule applies at any point in the race, whether the car is stopped or rolling or spinning. "under any circumstances" is clear enough, it means all the time. That is the rule that Red Bull is breaching, and I have no evidence suggesting other teams are doing so.
the suspension allows the sprung mass to bridge the gap. Your sarcasm shows you just missed his point.bot6 wrote:See Richard, I don't get how it can be clear ahead of the season that a rule will not be enforced. If that's the case, wouldn't scrapping the rule altogether be clearer?
And I still haven't seen a bit of suspension touching or nearly touching the ground on a non-damaged F1 car. Have you?
And don't tell me the tires bridge the gap, again not the sprung part of the car.
Will anyone bother to read the bloody regulations before commenting?
sure bot6, are we reading the same rules?bot6 wrote: 747heavy, please read the rules. Suspension does not attempt to touch the ground. Not unless it's broken.
ask yourself, if, when the spring in the suspension compresses, it brings the "sprung part of the car" closer to the ground.Any device or construction that is designed to bridge the gap between the sprung part of the car and the ground is prohibited under all circumstances.
Maybe you have different set of rules, because in the 3.15 it says "bridge the gap", which, as others pointed out, imply a constant state, rather then a temporary occurance.bot6 wrote: The rule does not forbid bridging the gap. It forbids attempts to bridge the gap. Again, read the rules please.
