Hahahaha I realized only now, but I won't edit that
Yes, but as far as I remember rumors said that 3D printing machines just arrived and Ferrari team was making calibrations and so on.
There is no second oil tank and no sump. The crankcase is probably divided into chambers with minimal volume for each cylinder pair.
I've heard in another from that oil burning is illigal and oil amount is regulated. I guess that second oil tanker is used for just better packaging.
I don't disagree, but what makes you sure of this?
In the beginning of this season I've heard an interview from one of former F1 car designers (don't remember who it was) that the oil tank in the floor just doesn't make sense. I.e. that CoG advantage is just not worth the value given other issues that arise with such design. Maybe he meant either aero disadvantages or extra weight of pipes of packaging issues, etc.
I believe djones was asking about a second tank for 'fuel-like' oil. This is specifically forbidden.roon wrote: ↑02 Jul 2017, 23:07I don't disagree, but what makes you sure of this?
If the floor bulges were oil tanks, they would have offered a CoG advantage. Two low flat tanks instead of a tall central tank in front of the engine. Polar moment perhaps similar or worse.
A thin flat tank with a pipe around the perimeter would be able to pull oil regardless of acceleration direction & sloshing.
How much oil can they carry? How much would this weigh? Could they have been pumping oil from one tank to the other as active ballast?
Both stories (the original from the end of January and this recent one) are by the well experienced and respected Italian journalist Franco Nugnes (formerly of OmniCourse, now at it.motorsport.com).PlatinumZealot wrote: ↑30 Jun 2017, 01:03Its all circular rumours.
The information given on that page was likely scraped off the floors of forums like this one.
ripper wrote: ↑28 Jun 2017, 14:59https://it.motorsport.com/f1/news/ferra ... ra-924343/
Short summary:
- ICE number 3 in Silverstone for both Ferrari cars
- Hamilton in Baku Q3 used the "overboost" on a scale of 8 on 10 (10 max power) and the Mercs used a special fuel on qualy, that wasn't used for the race because they feared that during SC temperatures might rise too much
- New Ferrari ICE should have changes in combustion chamber, it should have 400 bar pressure in the combustion chamber and a compression ratio of 16:1
- There are rumors about steel pistons done with addictive manufacturing with more resistance than aluminium ones, but only slightly heavier, due to honeycomb structure that helps also with heat dispersion
- This ICE should have also changes in the TJI system and should adopt also a new Magneti Marelli's double anchor micro injector that should be able to do multi injections (pre-combustion, combustion, cooling).
- New Shell fuel should be used with this ICE
- From first 062 PU to this evolution there are rumors about 50 hp gain
