subcritical71 wrote: ↑21 Feb 2020, 11:01
Holm86 wrote: ↑21 Feb 2020, 10:09
according to that logic, it should't be legal to turn the steering wheel either, if the wheel is part of the suspension, and the suspension is only allowed to change under load
I was thinking the same, but there must be another rule which allows steering (obvious as it may be) which may also allow the DAS to be legal.
Just a few thoughts,
Section 10.1.2 is applicable to the sprung suspension, which the wheel is not part of
1.13 Sprung suspension :
The means whereby all complete wheels are suspended from the unit comprising the survival cell/power unit/gearbox by a spring medium.
And I don’t interpret 10.2 as being applicable to the steering system because 1) it would not allow steering, 2) depending on how they are affecting the change in toe, there may be no movement of a suspension member. My guess is they are moving the steering linkages to do this and that is not part of the suspension.
Now, could the stewards deem it a driver aid or moveable aero... who knows!
This is the section of the regulations that descibe steering
10.4 Steering :
10.4.1 Any steering system which permits the re-alignment of more than two wheels is not
permitted.
10.4.2 Power assisted steering systems may not be electronically controlled or electrically powered.
No such system may carry out any function other than reduce the physical effort required to
steer the car.
10.4.3 No part of the steering wheel or column, nor any part fitted to them, may be closer to the
driver than a plane formed by the entire rear edge of the steering wheel rim. All parts fixed to
the steering wheel must be fitted in such a way as to minimise the risk of injury in the event of
a driver’s head making contact with any part of the wheel assembly.
10.4.4 The steering wheel, steering column and steering rack assembly must pass an impact test,
details of the test procedure may be found in Article 16.5.
To me 10.4.1 does not describe that the re-alignment of the wheels during steering has to be in the same direction, only that a maximum of two wheels can be realigned. Which is what happens with DAS
