KimiRai wrote:
15 Nov 2024, 12:20
Dan Fallows is paying the price, needless to say. As technical director, he has not convinced the management. At the moment it is still unclear what his position within the 2025 framework will be. There is even talk of a possible farewell, because a subordinate role in the Valkyrie project, moving to the WEC, would not be welcome. Cardile comes to Aston Martin through the front door. The 49-year-old from Arezzo is the new ‘chief technical officer’. Enrico will manage all the supervision regarding the technical development of the car, under the watchful eye of Adrian Newey.
The Stratford-Upon-Avon genius has always had clear ideas and prefers to command an operational pyramid that is not too large. A complex department in its form slows down decisions. For this reason, according to information, Cardile should directly absorb all of Fallows' tasks, making the “operational exercise” of the factory more agile and functional. So many responsibilities for the ex-Ferrarista, which would, however, reduce the working time of the British racing stable and not a little. This is the scheme that Aston Martin will adopt from the next world championship.
https://www.funoanalisitecnica.com/2024 ... s-via.html
Cowell: ‘If you have a little time to think, you realise what's important to you, and to me, is efficiency. What I hated in HPP was the waste of time’
‘I would get annoyed when I saw that something wasn't working efficiently. For example, when responsibilities overlapped. It was even worse when there was a gap and a lack of communication,’ he reiterates.
https://www.motor.es/formula-1/andy-cow ... 05263.html
So it seems Cardile will just take over Fallows' responsibilities. Newey and Cowell seem to both want a simplified pyramid which is a good idea, there were too many cooks and duplicitious roles for sure. Probably a Whitmarsh McLaren legacy...
Transition until everyone ends gardening and gets working in proper roles and hope Honda does well from the start. Fingers crossed.
Going after Newey and Cardile could be evidence that Lawrence was done with Fallows back in April. That's the way I'd do it. I'd leave the guy there and start looking for a replacement. It's what he did with Otmar, hired a replacement then started taking responsibility away and Otmar left on his own.
It's Lawrence that's been doing all the hiring. Whitmarsh didn't seem to have much to do with the day-to-day. He seemed more involved with the the 3 buildings. That work is done so he's being replaced by a racer.
I also don't think Cardile Left being a TD at Ferrari to be TD at AMR. He came to be CTO, so yeah he's responsible for the TD but he's not gonna do the job. He'll find a replacement or adjust the structure where those responsibility go to more than 1 person.
Rikrikrik
Rikrikrik
diffuser wrote:
15 Nov 2024, 16:02
Rikrikrik wrote:
15 Nov 2024, 15:23
Anyone know when AM will can literally starts to use the new WT? not configure, not comissioning, literally desfrute of the data and develop things on it.
I posted a September article in here not long ago that said December/January time frame. They'll then run both in parallel (comparing results) till they're happy that they don't need the Merc one. I presume that will be fast as nobody wants to keep going to the Merc WT on Friday till Sunday.
Yeah but, im questioning myself. If they cant understand own problems, how they can commisioned and calibrate the new WT properly and with precision if they cant work "decently" in Mercedes. I dont understand nothing about these things, but, for me these things are correlated, no?
Rikrikrik wrote:
15 Nov 2024, 17:42
diffuser wrote:
15 Nov 2024, 16:02
Rikrikrik wrote:
15 Nov 2024, 15:23
So the correlation Fallows described as being the problem was the interaction between the floor and the ground in different turn scenarios(speed, bumps, roughness of the pavements, etc). Maybe the Merc WT just doesn't have the tools to look into that? It wasn't that they didn't achieve the DF levels. It was that it fluctuated to the point that the drivers lost confidence in the car.
diffuser wrote:
15 Nov 2024, 19:07
I would find it strange if the Mercedes windtunnel didn't have the right tools considering they were the highest spender in the sport before the budget cap.
A lion must kill its prey.
15 Nov 2024, 19:11
diffuser wrote:
15 Nov 2024, 19:07
There wasn't anybody looking at the aero under a flat floor that was the only thing allowed prior to the reg change of 2022. Just the diffuser.
