2024 Scuderia Ferrari F1 Team
ScuderiaLeo
Why was Austria expected to be better for the SF-24 compared to Spain? Is it because they didn't anticipate the bouncing to occur at these speeds and so they expected the car to be easier to handle?
ScuderiaLeo wrote:
29 Jun 2024, 10:48
Thin air -> less downforce -> porpoising less likely to be triggered. In past porpoising has been seen the most when high downforce is run. Low speed and medium speed corners were pretty good for Ferrari earlier in the season. Austria has high temps and rough asphalt which should hide some of Ferrari's tyre issues. And quite a bit of time to be made in heavy braking zones into the slow speed
dani5549
dani5549
Amazing start
ScuderiaLeo
Why did they ask them to LICO? Underfuel at the start? Brake temperature?
yooogurt
16
Suffering in the high-speed corners continued, Sainz was getting close to Georges in drs, and then lost everything in 6-7 and 9-10.
Not surprising, in the quali was the same, the rivals as on rails, and our struggling with the car.
Well, probably they will change something in the settings, lets see what happens in the end.
FORZA FERRARI!
hape
hape
ScuderiaLeo wrote:
29 Jun 2024, 12:29
High brake temp
Deliman Cristian
Deliman Cristian
yooogurt wrote:
29 Jun 2024, 12:33
Still some isue with traction out of the turn 1 and 3, but high speed corner are bad. Simply lose the front of the car and went wide
ScuderiaLeo
Leclerc's start was fantastic but that's pretty much where the positives end for me. Neither driver sounded happy with the car at all. Even though 3 positions were gained, this sprint looked more like a loss. We've been repeatedly told that the car will be better in race pace or that the next track will be better, but that just isn't the case. Maybe the raw pace is fine but they're not going to be able to take true advantage of it if the car itself is unstable and constantly having brake temperature issues.
It did make me laugh when Sainz said on the radio "tell me something I can do that's not LICO for once". :P
So what can be done before qualy? Is it worth trying the Barcelona RW?
Xyz22
Xyz22
104
This looks really bad, not gonna lie.
Edit: Leclerc said is going to try something extreme in terms of setup because they are just slow right now.
SoulPancake13
SoulPancake13
Sevach wrote:
29 Jun 2024, 12:58
Charles said there is no miracle solution, he will likely try a more extreme setup just to try something.
Xyz22
Xyz22
104
SoulPancake13 wrote:
29 Jun 2024, 13:03
Sevach wrote:
29 Jun 2024, 12:58
This means the situation is really bad.
yooogurt
16
Xyz22 wrote:
29 Jun 2024, 13:06
who would have thought, team got more DF than they expected, and it turned out so bad, damn.
FORZA FERRARI!
yooogurt
16
29 Jun 2024, 13:03
Sound like they will lowered car and try to fight vs bouncing
FORZA FERRARI!
venkyhere
venkyhere
So where have Ferrari landed up ? Is it a case of :
tunnel heights lowered to get more DF from floor -> oh s**t, porpoising in high-speed is back -> have to increase ride height -> oh s**t we lost downforce -> we need more front and rear wings -> well, we are draggier than the other three.
Is that the right summary ?
