amouzouris wrote:That is another thought I had, which might also explain why the hole is so tall...If they wanted to just peel off the boundary layer a much shorter hole would have done the job
I probably should have said the inlet reduces mass flow to counter the increase in pressure caused by an adverse pressure gradient. I think that's more illustrative of what's really going on.
Either way, I think the inlet has to be large enough to work at all speeds without choking, and it has to be small enough to avoid drawing in too much air.
EDIT: Incidentally, you did find an adverse pressure gradient.
R_Redding wrote:What are the perforated sections in the splitters bow for ?...
That could be where the system vents. Small ducts oriented in the direction of flow could perhaps energize said flow. (If so, I'm really starting to love the multi-faceted elegance of this system.)
But, then I wonder if those ducts could vent fast enough to keep the system itself from choking.
