I think two fuels are allowed.
Relevant parts of the regs I guess.
19.7 Fuel approval :
19.7.1 Before any fuel may be used in an Event, two separate five litre samples, in suitable
containers, must be submitted to the FIA for analysis and approval.
19.7.2 No fuel may be used in an Event without prior written approval of the FIA.
19.7.3 No competitor may have more than five fuel formulations approved for use during a
Championship season.
19.7.4 No competitor may have more than two approved fuels available during an Event
400 is very high but it does agree with a statement from Mercedes last year (elephants on pistons) which suggested 400+ bar.
B/S ratio is currently ~1.5 compared to ~2.5 for the V8s.The v8 had 13-14 CR and that was a geometrical limitation. I don t see how you can get 16 without reducing valve lift considerably or designing a piston with massive recesses.
I thought the idea was to maximise the heat in the combustion chamber to create power in the expansion stroke or in expansion through the turbine.
& especially with 'turbo-boost' - being pumped in, @ several times ambient-N/A's best volumetric levels..gruntguru wrote: β05 Jul 2017, 00:06400 is very high but it does agree with a statement from Mercedes last year (elephants on pistons) which suggested 400+ bar.
Apart from that, engines making peak power at 11k rpm don't need as much valve area and lift per unit displacement as those making peak power at 17 or 18k rpm.
I'm guessing to maximise the average temperature in the cylinder you need to minimise the peak temperatures, the hot spots. Perhaps a "honeycomb" structure could be used to micromanage the heat flows in the piston reducing the hot spots, increasing the average temperature and doing so with limited weight penalty.wuzak wrote: β05 Jul 2017, 03:06I thought the idea was to maximise the heat in the combustion chamber to create power in the expansion stroke or in expansion through the turbine.
Dissipating heat through the piston to the cylinder walls, oil or the air in the crankcase seems like something to be avoided if possible.
Wow ! I didn't knew that..I've heard no comments from any TV commentator or expert regarding qualy fuels. Do they just think it has no meaningful effect, or just plain lack of knowledge ? Do we know from a reliable source that they are indeed using this rule to have a separate qualy fuel mix ? Sorry, it's a becoming OT now.3jawchuck wrote: β04 Jul 2017, 16:31Relevant parts of the regs I guess.
An enclosed honeycomb structure will work as an insulator, so its no good at dissapating heat. Unless it would be an open structure which oil was sprayed onto, but structually i can't see how that would work.henry wrote: β05 Jul 2017, 09:57I'm guessing to maximise the average temperature in the cylinder you need to minimise the peak temperatures, the hot spots. Perhaps a "honeycomb" structure could be used to micromanage the heat flows in the piston reducing the hot spots, increasing the average temperature and doing so with limited weight penalty.wuzak wrote: β05 Jul 2017, 03:06I thought the idea was to maximise the heat in the combustion chamber to create power in the expansion stroke or in expansion through the turbine.
But wasn't this update supposed to be a revolutionary thing Ferrari did using 3D printing technology? I know I've heard this before in more than one article... An open honeycomb structure can be done using (relatively) low-tech CNC machinery and would have probably been looked at by several other engine technicians before. So I'm still wondering if they are trying to invent something cleverer than this...Tommy Cookers wrote: β05 Jul 2017, 10:52structurally it would work roughly as would using T section joists holding up a floor in a building
ie much better than the same amount of metal in the form of a notionally constant thickness (plate)
we need a controlled drain of heat to lubricant-as-coolant just as we drain heat elsewhere to coolant-as-coolant
ie an piston structure open on the underside as Holm has said
controlled to prevent excess piston crown temperature and consequent detonation or unsuitable behaviour
I remember looking into the elephants claim and I think it gives something like 350 bar +/- 100 depending on the species and gender of elephant.gruntguru wrote: β05 Jul 2017, 00:06400 is very high but it does agree with a statement from Mercedes last year (elephants on pistons) which suggested 400+ bar.
In addition to what PZ said, steel is a very good insulator compared to Al. I think just by swapping to steel you would decrease heat rejection to oil. The downside is that this makes it very hard to control crown temperatures for durability reasons.wuzak wrote: β05 Jul 2017, 03:06I thought the idea was to maximise the heat in the combustion chamber to create power in the expansion stroke or in expansion through the turbine.
