FoxHound wrote:And to Ben,
Would you say this effect is more pronounced with raked cars?
The concept is irrelevant.
An adverse pressure gradient is a region where static pressure increases in the direction of travel. This is problematic, because air would much rather flow from areas of high pressure to areas of low pressure, as areas of varying pressure will always seek to equalize.
Ultimately, that means air flow along an adverse pressure gradient steadily loses dynamic pressure - the kinetic energy of the air flow itself - as it overcomes the effects of the adverse pressure gradient. If boundary layer flow along an adverse pressure gradient loses too much dynamic pressure, it will separate. By separate, I mean it will reverse itself, as areas of varying pressure will
always seek to equalize...
Exaggerated for effect
If that were to happen on a Formula One car as described in the Motorsport article, the size of the car's wake would be increased significantly, which would increase drag significantly, because it would create the mother of all bottlenecks. It's a senseless outcome.
And this is supposed to happen to RB12 as a drag-reduction strategy? After the severity of the rear wing's adverse pressure gradient has been minimized due to reduced rake from aero loading? In other words, the senseless outcome is supposed to occur magically?
Less rake = lower AoA
As my friends in New Jersey would say, "Get the --- outta here!" (The idea presented actually comes closer to explaining how rear wings create downforce.)
If you have a pet, ask for its thoughts on the subject. The answer you receive will make exactly as much sense as what was written in that article.
EDITS: clarity
