Are you putting left and right in the same STL?CAEdevice wrote:If you put a generic "mid-surface.stl" in the monitoring surface folder it works.RicME85 wrote:what are we naming the monitoring surface inside the heat exchanger?
Has WFlow been updated to work with the new rule changes?
(I don't use the GUI)
Does WFlow run ok without the inlet and outlet surfaces?
