So here in slow motion you can see how the valve works in a four-stroke internal combustion engine .. You can see perfectly the "precision" of this mechanism .. It is best to watch it on the maximum screen .. You can see how the valve is when not pressed (and then there is a stroke of work with high pressure ) we are simply shaken by the effect of spring vibrations bouncing off the valve face and inertia .. At the bottom of this valve there is a "mushroom" which closes the way to the cylinder .. But since the valve stem dances so, the mushroom also makes such movements .. A since it performs these movements, even when it is "theoretically" closed, it really does not close the cylinder tightly, despite the fact that it is subject to a stroke pressure of up to 100 atmospheres. And we can imagine how much of this pressure escapes from the cylinder, on the effect of these "supposed" small, but very spoiling cylinder tightness, the movements of this mushroom .. Because at a pressure of 100 atmospheres, we can imagine that even a small gap, however, can even drop to 30 atmospheres make .. this mechanism is economical, and produced in virtually all internal combustion engines .. And complacency that the valve will be tight, because it presses it to the seat, high pressure in the cylinder is only the "wishful thinking" of the designers of such a system. because you can see that this is not true, because the valve sways and bounces off the socket, just when it should be closed ... This film helped me understand why my engine without these valves has such high efficiency and power, because how it receives in the cylinder, these 100 atmospheres, I will never lose my tightness all the time, closing the "valve", maybe like 2 atmospheres .. Well, but the amount of energy to use will be 3 times greater than in a traditional engine ... because 98 atmospheres .. And so on every cylinder .. adding to this even 40% more displacement, and twice as high achievable maximum revolutions, it also receives incredible power ten times greater than the original factory engine ... the load. Well, to find out about all this, I had to do [for 3 years of hard work a prototype of this engine, and say that it is so, although at first it did not seem to me at all, that so much is possible .. But it is thanks theoretically, to drive a Toddler (Fiat 126), with the same power as the original, you need a motor that will be smaller these ... 10 times .. But all this can not be determined by just watching the animations of my engine and criticizing me .. You need to spend your private million dollars to find out that this is the case ... And this film also shows that it is possible with all the imperfections of the current valve system ...
Even an indicator pressure test on an oscilloscope shows us that the pressure drops, but does not show us WHERE it escapes ...
https://www.youtube.com/watch?v=adYrRk22GDQ
Andrew
