Avoidance of debris would be shown as a correction (left-right)Tim.Wright wrote:No, nothing is ever crystal clear because car behaviour is not a one dimensional thing. 50% of the problem is finding out if the strange things you see are the CAUSE or EFFECT of the accident.Andres125sx wrote:
Nothing is crystal clear in the telemetry...... if you don´t see driver suddenly turned the wheel with no reason, or if you don´t see a drop in downforce, or if you don´t see battery voltage suddenly dropped, or if you don´t see driver suddenly stopped making any input.... There can be tons of facts wich would be crystal clear just watching the correct data in the telemetry
As for your list:
Driver turns to the left for no reason: avoidance of debris or something on track? correction due to loss of grip, tyre failure? response to car failure? driver blackout?
Loss of grip also would be shown as a correction, and would be noticed watching more data as wheel spin, throttle position, etc.
Tyre failure would be easily shown watching suspension data, and that scenario wouldn´t be a turn to the left with no reason, but with multiple corrections to the wheel. It would also be easy to see watching the car after the crash
Debris wouldn´t change downforce equally (more or less) in the front and rear end as a wind gust would.Tim.Wright wrote:Drop in downforce: wind? debris in wings? aero element failure? loss in downforce due to a ride height change? suspension/ride element failure or deflection?
Aero element failure is easy to see analysing the car, if they can do it with a crashed airliner analising this McLaren wich didn´t suffer mayor damage would be very easy.
Ride height change is also easy to see in telemetry.
Suspension or ride element failure would also be shown with many more sensors, for example the opposite wheel would be in the air. Also analising the car after the crash would be unquestionable
Drop in battery voltage + no driver input = electrical shock.Tim.Wright wrote:Drop in battery voltage: defective battery? short circuit in H/Kers? short circuit in ignition system? blackout/brownout of the logger?
Drop in battery voltage + normal driver input = short circuit at some point.
If the battery is defective that´s quite easy to see after the accident
No driver input from loose of control to the crash itself would equal to driver unconsciousnessTim.Wright wrote:No driver input: defective sensor? driver is pre-occupied with another problem? driver is distracted by radio? siezed steering?
No driver input at the exact loose of control and driver input after that would mean he could be distracted
No driver input and locking brakes would mean siezed steering, and again, would be easy to see watching the car after the accident
I´ll repeat it just in case..... I´m not saying they should publish telemetry, but with the car and the telemetry they have more than enough data to know more or less what happened. If they don´t say what happened it may be due to multiple reasons (car failure, mechanical failure due to some mechanic mistake, engine problem wich Honda don´t want to be public, marketing reasons....), but they do know what happened for sure
