2021 Engine thread
roon
roon
412
Re: 2021 Engine thread
Unsprung weight. Not to beat a dead horse. How light can an 80+HP (more harvesting potential than rear axle) MGU be made? I'd wager the wheel, tire, and suspension at each corner of the car currently doesn't exceed 30lbs.
wuzak wrote:
17 Oct 2017, 01:33
Nice pic, but I think the MGUK would be smaller than the diff. It would sit in there ahead of the bulkhead.
Smaller in volume or mass?
Zynerji
111
roon wrote:
17 Oct 2017, 01:43
Integrating it into the shroud and rim wouldn't add more than 5lbs.
470
roon wrote:
17 Oct 2017, 01:43
wuzak wrote:
17 Oct 2017, 01:33
Volume.
Still, the current MGUKs aren't all that weighty.
roon wrote:
17 Oct 2017, 01:43
The weight would be offset, somewhat, by the reduction in the size of the brake and caliper required.
648
the present K runs only from 30000 - 40000 rpm because they want it to
(thanks to the 8 speed transmission it runs at eg 70 - 100% of max rpm and eg 100 - 70% of max torque)
the air gap is very small, giving high efficiency in the magnetic circuit
a much higher torque, larger diameter, lower rpm direct drive equivalent is a whole new and different thing
I promise it and its drives will be less efficient and need more cooling
conceptually it now has to run at eg 10 - 100% of its new max rpm and eg 100 - 10% of its new max torque
and incorporate additional mechanical functionalities
public utility power generators are efficient - they run at a constant 100% rpm and constant torque
F1's 8 speed transmission is beneficial to the electrical machine side as it is to the mechanical machine side
imagine F1 with direct drive ICEs
63l8qrrfy6
63l8qrrfy6
368
Well Merc's project one has MGUKs geared down and driving the front wheels. The 2 gearboxes are probably heavier than anything else at the front end.
Jejking
Jejking
Zynerji wrote:
17 Oct 2017, 01:48
roon wrote:
17 Oct 2017, 01:43
What issues would such an integration potentially bring?
648
[quote=roon]Unsprung weight.....How light can an 80+HP (more harvesting potential than rear axle) MGU be made? [/quote]
isn't there really less harvesting potential from the front axle than from the rear ?
average braking recovery is with a weight+DF distribution c.50/50
and much 'recovery' is done under power
Jolle
Jolle
133
Tommy Cookers wrote:
20 Oct 2017, 12:27
roon wrote:Unsprung weight.....How light can an 80+HP (more harvesting potential than rear axle) MGU be made?
there surely is less harvesting potential from the front axle than from the rear
because 67% of the weight and 67% of the DF is on the rear
A F1 car can brake faster then it accelerates, the potential energy that you can get from the front axle is probably around 2000 HP. For the deployment the numbers are a bit different, prob around max 500HP
648
2000 hp or any other hp is not energy it is the rate of energy transfer
2000 hp is a momentary peak - total time at braking powers over 1000 hp per axle is only a few seconds per lap
the K and its drive electronics and ES are 161 hp devices not 2000 hp devices
broadly 2000 hp devices are 13 times bigger, and they weigh 13 times as much the whole lap
also much of the present K 'recovery' energy/lap is made under power not braking
the 161 hp K is a handy size for this - part of the beautiful ingenuity of the present rules
actually the K is as much a constant torque (not constant power) device ie the power falls below c. 6000 (crankshaft equivalent) rpm
practical direct drive of the front axle is compatible with this sort of factor
(ie even if you had eg 500 hp from the front EMs at the start or exiting Loew's you couldn't apply it all to the track)
usefully an MG-driven front axle wouldn't need a very fast-responding MG
because it's not slaved to a gearbox (needing very fast ICE and MGU-K response to minimise effective shift time)
roon
roon
412
20 Oct 2017, 12:27
Good point. They also don't dive very much under braking, so weight distribution changes shouldn't be as drastic as I assume they would be.
470
20 Oct 2017, 12:27
Brake bias is of the order of 60/40 - 55/45 front to rear. So yes, the front does have more energy recovery potential.
Jolle
Jolle
133
roon wrote:
21 Oct 2017, 00:05
20 Oct 2017, 12:27
"diving" has noting to do with the weight distribution but with how stiff the springs are.
The transfer of weight is not that difficult to imagine (or calculate). It's about how hight the COG is and how much force or deceleration there is. On car's it's not so obvious because the COG is relative low. On motorbikes it's more clear. Even a MotoGP bike with carbon brakes and slick tires only can brake around 1G because the high COG. The Fres of the deceleration (F going straight forward) and gravity (F going downward) result in a force going trough the contact patch of the front tire, making the brake balance 100% - 0%.
I don't think by the way that the brake balance on F1 cars (the 50%-50%) are the actual brake forces on the tires but more a fine-tune. The normal balance is for instance 70-30, and then they can play with between 60/80% - 40/20% or something, divided in 100 steps.
stevesingo
stevesingo
42
20 Oct 2017, 12:41
...also much of the present K 'recovery' energy/lap is made under power not braking
Although I understand that under certain conditions (preparing for a Q lap, during a Q lap or preparing for a SC restart) the ICE can be used as a generator, but during the race, when fuel is limited, why would you use fuel to charge the ES?
470
stevesingo wrote:
21 Oct 2017, 15:08
20 Oct 2017, 12:41
Because you can't charge the ES completely with braking alone.
Plus it allows you to use power you don't necessarily need at one point of the lap and use it at another when you want it.
232
Just_a_fan wrote:
13 Oct 2017, 15:18
Small gas turbine driving a generator, electric motors/generators in all four hubs. Unlimited battery capacity/discharge rate. Noise, smell, speed. Pure F1.
This would be cool. Also affordable, because those gas turbines would last the whole season.
I see ideas on giving freedom to develop different engine layouts. You can't control costs that way.
Standardization is the best method of cost control.
I see other propositions, but those aren't really new technology. There has to be the right amount of road relevance, entertainment, and technology which is yet to be used on the road.
This is why i suggested hydrogen fuel cell.
The V-10 was for the entertainment factor. And i still think a V10 or V12 is a very nice to have engine in a sports car. If you cancel out all the inefficiencies then why not have one?
A low revving petrol v8 with coil spring timing is too retro.. its basically going back to the 1960s.
The gas turbine generator that drives electric motors or hydrogen power is definitely the next big step.
