McLaren MCL35M
Re: McLaren MCL35M
It's just a rough comparison from differing angles, afaik the Mclaren floor is full width at the front. In fact if you look at the rear tyres instead of the line you see all the cars are using the max allowed by the regs there.
SmallSoldier
SmallSoldier
486
Re: McLaren MCL35M
mclaren111 wrote:Image
Seems Mclaren's floor are narrower than needed if this article is accurate ??
https://f1i.auto-moto.com/magazine/maga ... sagrandit/
The article doesn’t make a mention to Mclaren’s been narrower, it does state that is following the regulation “as intended”, meaning a continuous line from the widest part of the floor and that Alfa Romeo and Haas are the other 2 teams following that initiative.
If all teams are maximizing the size of the floor at the rear tire, then Mclaren’s isn’t narrower and in theory has more overall floor area (since they are not losing the area in the cutout).
What surprises me is how apparently simple the floor of the Mclaren is compared to the competition... Which if it is working, it is excellent since every single winglet creates drag ultimately and that simplicity is one of the contributing factors to how fast the car is.
SiLo
139
Re: McLaren MCL35M
mclaren111 wrote:
20 Apr 2021, 12:46
SiLo wrote:
20 Apr 2021, 11:50
That's wider not narrower.
If you look at the Turquoise Blue sections next to actual floor our's is wider & thus floor smaller / narrower...
Those are drawn poorly, the McLaren floor is as wide as it's allowed to be within the regs.
Felipe Baby!
McFAN
McFAN
Re: McLaren MCL35M
Anyone else notice ?
Seems to me to be a new engine cover,
it tapers in quite significantly over the rear suspension.
daren_p
daren_p
Re: McLaren MCL35M
McFAN wrote:
20 Apr 2021, 16:49
https://formularapida.net/wp-content/up ... S23116.jpg
They did run two different specs in testing, do you think this is actually a 3rd spec or just the tighter/less cooling outlet size they ran in pre season testing?
SmallSoldier
SmallSoldier
486
Re: McLaren MCL35M
McFAN wrote:Image
Imola was very cold compared to Bahrain, I would have expected a tighter engine cover and heat exit at the rear
McFAN
McFAN
Re: McLaren MCL35M
daren_p wrote:
20 Apr 2021, 17:29
McFAN wrote:
20 Apr 2021, 16:49
I don't remember seeing this spec in testing, I might have missed it though,
But its definitely quite different than the launch spec no?
Jackles-UK
Re: McLaren MCL35M
McFAN wrote:
20 Apr 2021, 16:49
Hadn’t realised quite so much metallic material is being used in the front portion of the car until this photo. Quite impressive workmanship to integrate all the mixed materials.
Re: McLaren MCL35M
Looks good...
Re: McLaren MCL35M
Front of the RW endplates turns inwards... Is this new ??
Re: McLaren MCL35M
Doesn't really say all that much per sé, those numbers would be affected by a lot of things, all different for the different traps.
afaik McLaren deploys their ERS really early on, and such mappings can really affect those numbers
_cerber1
268
Re: McLaren MCL35M
mclaren111 wrote:
22 Apr 2021, 14:45
I have not seen such a thing before. Perhaps this is indeed McLaren's find.
_cerber1
268
Re: McLaren MCL35M
We need a photo of the back with a new engine cover. :roll:
SmallSoldier
SmallSoldier
486
Re: McLaren MCL35M
The inward portion of the endplates is new for 2021, but not for Imola... The new endplates were present in the renders of the car at launch.
Re: McLaren MCL35M
Thanks...
