gruntguru wrote:xpensive wrote:That is a most resonable estimation; With 46 MJ/kg, 27.8 g/s flow and 35% efficiency you get 450 kW or 600 Hp.
MGU-K is limited to 120 kW or160 Hp, wherever the electricity is coming from, the ES or the MGU-H.
Total 760 Hp means a total efficiency of 44%
That is not a valid application of the word "efficiency and I doubt that Mercedes would quote a number that includes the total power to the MGUK.
The "more than 40%" quoted by Mercedes would include power from the crankshaft and (probably?) power being simultaneously generated by the MGUH under steady state conditions.
600Hp from the ICE is the figure we have seen bandied about for a few years, which I believe is the basic conservative estimate. Marmorini quoted a range with 650Hp being the upper limit (a figure that is greater than what some posters believe to be possible), which he believes is reasonable. So why would an engineer working on the PU, with intimate knowledge of the programme quote an unattainable (according to some here) figure
xpensive posted of 600Hp from the ICE, with 160Hp from the ES/MGU-H leading to a total of 760Hp and a total efficiency of 44%. Now Andy Cowell of Mercedes HPE during the 'Power-Unit Manufacturers' press conference in China mentioned a
'giant leap' going from NA ICE engines with about 30% thermal efficiency to engines where they are
'all targeting 40%' thermal efficiency and that a
'huge step' a
'huge introduction of new technology both on the internal combustion engine for efficiency and also on the two energy recovery systems...' had been made.
Rob White from Renault later added during the same press conference
'I think Andy was cautious when saying 40%, I think to be competitive you need to be a bit better than 40% already, I think we shouldn't underestimate just how important that is in terms of automotive technology.'
If Andy was referring to
'all targeting 40%' total efficiency, this is 4% lower than the general figure xpensive mentioned and would result in an output less than the 760Hp
basic output that has been quoted for a very long time now. So why would Andy mention 40% total efficiency, which results in an output well below the basic figure in the public domain which has been quoted by Renault for instance
