If anything a shorter crank should be stiffer in torsion and likely have a smaller inertia so I can't see it being worse for TV.dren wrote:I read on another site the rumored 'trick' short crank is causing vibration issues which are compounded elsewhere. Question: "Did anyone do firing order analysis on the audio? If so, I can't find it. I remember seeing something but thought it was for an older PU. That could shed some light on the crank rumor.
Another question: "Is Honda testing a slew of single cylinders on a dyno and waiting until the last minute to throw together 6 of the best performing ones?"
Also word on the street is they have been doing some single cylinder work in UK with a small team not sure if anything came out of that - this appeared to be independent of the ilmor rumors.
