2024 Mclaren Formula 1 Team
LionsHeart
LionsHeart
Very tight in every sector. The top speeds are also comparable. Considering that McLaren is again at the bottom of the list, but it is only a couple of kilometers per hour to the other top teams. There is no real advantage here, since acceleration at the exit of the corners is much more important.
McLaren is still the most efficient at the exit of the corners and accelerates more intensely than the others. Even taking into account a small loss at the end of the straights, the chassis still passes the sectors faster than the others, well, perhaps Red Bull can counter with something.
To sum it up: Globally, the chassis no longer suffers from an acute deficit in top speed, as well as an acute deficit in speed in slow corners.
It remains to be seen how effective the updated kit will be on low-downforce tracks. It hasn't been there yet. Baku, Spa, Monza, Las Vegas. That's the weakest point so far, based on last season. That means the team needs to make a new rear wing.
Emag
Emag
137
LionsHeart wrote:
28 Jun 2024, 21:42
https://i.ibb.co/n6khsrb/2-B7-F348-C-60 ... 3332-F.jpg
https://i.ibb.co/M7nVVB0/B2-E12-D02-C07 ... 30-DAB.jpg
https://i.ibb.co/HPHbh83/91-B4-D049-AFD ... 3-F7-C.jpg
Basically, only with a perfect first sector would Lando be able to snatch pole away from Verstappen today.
The RedBull just flies in the high speed stuff.
Developer of F1InsightsHub
LionsHeart
LionsHeart
Emag wrote:
28 Jun 2024, 21:47
LionsHeart wrote:
28 Jun 2024, 21:42
The first sector was already decent. There is no point in discussing how Lando could have taken pole. He didn't. Another attempt will be tomorrow. Let him give it his all there.
Emag wrote:
28 Jun 2024, 21:47
LionsHeart wrote:
28 Jun 2024, 21:42
Yeah I think usually red bull were commanding in s3 but Lando would have Max's number in S1. However in the final sq3 laps max had the better S1 but struggled in T9-T10. I think neither Lando nor Verstappen put sensational laps together. Most likely to do with the slightly compromised outlaps as a result of traffic & tight time cut
BMMR61
With the new parts they had quite a lot to do to be ready for SQ. The expectations of some here is off the charts. P2 & P3 is perfectly decent and with a 3 tenths gap to the Mercedes on this short lap is fair. I don't know how people's expectations can be met quite honestly. There's every reason that 0.09 can be bridged by the time they get to the main qualifying with some further optimisation of the new bits. It's Sunday that the real points are handed out not the sprint.
LionsHeart
LionsHeart
28 Jun 2024, 21:53
Emag wrote:
28 Jun 2024, 21:47
LionsHeart wrote:
28 Jun 2024, 21:42
On a fast lap, it's easy to overheat the tires. The weather is warm. It will be even hotter on Saturday.
The difference between the cars is too small to judge who could potentially win where and in what place.
LionsHeart
LionsHeart
BMMR61 wrote:
28 Jun 2024, 23:37
People are like that, sometimes impatient. :)
stonehenge
stonehenge
McLaren has been quicker in race pace since Imola. Their biggest weakness remains qualifying. Tomorrow will be super interesting because I reckon both McLarens should pass Verstappen on pace--however, they need a clean getaway. I think this weekend will tell us a lot about how the season may play out. Ferrari is clearly still lost. Mercedes is improving but probably *just* a few steps too far back. McLaren is the team that can challenge Red Bull. They need to start winning. Let's see how this plays out!
LionsHeart
LionsHeart
Some more telemetry
LionsHeart
LionsHeart
stonehenge wrote:
28 Jun 2024, 23:45
Amen 🙏
mwillems
It is interesting comparing the telemetry to the mini sector maps we are seeing.
It makes it look like the Mclaren has great traction. But like last week, it appears more to be an artifact of the way McLaren attack the corner, which is to either scrub speed quicker and earlier than Max, or to start scrubbing speed earlier than Max. Either way, they are doing more work earlier or harder on the entry of the corner to ensure the car can carry speed at the apex and is ready to exit as early as possible. This creates the impression that we have great traction, but in reality it is because the car appears that it can be worked more on entry to the corners and because Lando has obviously found a great way to get the most out of the car in these corners. The speed we carry through the corners is also being carried down the straights. As already mentioned, speed with DRS open is slower than other cars, but it doesn't matter because for the bulk of the straights we are faster by 5+ kph.
The only corners that I can see that we lose out to Red Bull are 4, 7 and 9. 7 and 9 are Over 220kph, which is where RB start to get the advantage. Turn 4 is an odd one, not sure if he made a mistake here or not.
We were also uncharacteristically slow on the start finish straight at the beginning of the lap, probably losing us .04
-Bandit
Tomsky
Tomsky
29
trinidefender
trinidefender
318
Did both cars get the new front wing?
Piastri said in the interviews that the wing was working well.
Tomsky
Tomsky
29
trinidefender wrote:
29 Jun 2024, 05:12
Yes
LionsHeart
LionsHeart
29 Jun 2024, 05:12
Having watched the sprint qualification, I can confirm.
