F1i Magazine
http://encdn.f1i.com/wp-content/uploads ... gine-3.jpg
http://encdn.f1i.com/wp-content/uploads ... gine-6.jpg
http://encdn.f1i.com/wp-content/uploads ... ine-51.jpg
2016
I asked this the other day because there appears to be something to this.jure wrote:Is there any connection between plenum size and engine power or anything else? I've been wondering what's the reason for different plenum shapes and sizes between different manufacturers. For example, Mercedes has two large plenum chambers (one for each bank of cylinders?) at the top of the engine.
My take (not an engineer, car enthusiast only) is that it may have to do with the split arrangement of the turbo/compressor unit. That Merc. have a plenum inlet for each bank makes me think the space in the "V" is taken up by MGU-H and anything else that permits the split. They said it was hard to do the split. The massive task of overcoming the difficulties is probably why the other manufactures have not done it.hurril wrote:I asked this the other day because there appears to be something to this.jure wrote:Is there any connection between plenum size and engine power or anything else? I've been wondering what's the reason for different plenum shapes and sizes between different manufacturers. For example, Mercedes has two large plenum chambers (one for each bank of cylinders?) at the top of the engine.
These things are such that I can understand them and I think I did from the start. What we're wondering now is what the benefits are to having these fairly large plenum chambers. Mercedes' were very large even before the variable intake trumpet-rule was invented.bidness wrote:My take (not an engineer, car enthusiast only) is that it may have to do with the split arrangement of the turbo/compressor unit. That Merc. have a plenum inlet for each bank makes me think the space in the "V" is taken up by MGU-H and anything else that permits the split. They said it was hard to do the split. The massive task of overcoming the difficulties is probably why the other manufactures have not done it.hurril wrote:I asked this the other day because there appears to be something to this.jure wrote:Is there any connection between plenum size and engine power or anything else? I've been wondering what's the reason for different plenum shapes and sizes between different manufacturers. For example, Mercedes has two large plenum chambers (one for each bank of cylinders?) at the top of the engine.
The split is brilliant in my view in that it allows a cooler initial air feed (as opposed to taking the air to the rear of the engine where the other manufactures' compressors sit). Its always going to be cooler in front of the engine instead of near the hot turbo. The placement in the Merc. shortens the ducting and probably (at least in my thinking), allows for a more energized flow of air. So the Merc. has benefited from the layout with only the small downside of splitting the plenum feed.
Maybe they are not as large as you think they are is what I was alluding to in my post. We are only seeing the outside carbon fiber shroud but what does the inside look like? I suggest two smaller chambers with *things* taking up space in the middle. This is why (my guess) that the Merc. Plenum is so large.hurril wrote:These things are such that I can understand them and I think I did from the start. What we're wondering now is what the benefits are to having these fairly large plenum chambers. Mercedes' were very large even before the variable intake trumpet-rule was invented.bidness wrote:My take (not an engineer, car enthusiast only) is that it may have to do with the split arrangement of the turbo/compressor unit. That Merc. have a plenum inlet for each bank makes me think the space in the "V" is taken up by MGU-H and anything else that permits the split. They said it was hard to do the split. The massive task of overcoming the difficulties is probably why the other manufactures have not done it.hurril wrote:
Oh! Good point!bidness wrote: Maybe they are not as large as you think they are is what I was alluding to in my post. We are only seeing the outside carbon fiber shroud but what does the inside look like? I suggest two smaller chambers with *things* taking up space in the middle. This is why (my guess) that the Merc. Plenum is so large.
Do two engine brands( Renault and Tag heurer) have separate engine tokens? and if they have then Renault can test different parts by using tokens of another team and decide for improving their engine for their next tokens.Silent Storm wrote:Some differences between the two.
https://twitter.com/albrodpul/status/702247933991845890
No.amho wrote:Do two engine brands( Renault and Tag heurer) have separate engine tokens? and if they have then Renault can test different parts by using tokens of another team and decide for improving their engine for their next tokens.Silent Storm wrote:Some differences between the two.
