Aston Martin Red Bull Racing TAG Heuer RB14
Zynerji
110
Re: Aston Martin Red Bull Racing TAG Heuer RB14
rscsr wrote:
25 Aug 2018, 10:52
Zynerji wrote:
25 Aug 2018, 04:43
MtthsMlw wrote:
24 Aug 2018, 22:48
https://i.redd.it/6te0ah1vr3i11.jpg
open in new tab for high res
With the +/- 3mm variance allowed across the "flat floor", I'm somehow disappointed that there isn't any strategic "waves" to get aero benefit. Like golf ball dimples or similar...
McLaren tried something like that several years ago. They bent the tea tray upwards by the tolerance and it was forbidden.
Why have a variance set in the rules, then? It was +/- 5mm, and got changed to 3.
roon
roon
412
Flatness tolerance for manufacturing.
roon wrote:
25 Aug 2018, 16:59
I'd say more on montage than on manufacturing, it's not that hard to make a flat piece of composite, down to a tenth of a millimeter.
roon
roon
412
3.7.5 Tolerances
To help overcome any possible manufacturing problems, and not to permit any design which may contravene any part of these regulations, the following dimensional tolerances are permitted on bodywork situated between 430mm behind the front wheel centre line and the rear wheel centre line: a vertical tolerance of +/- 3mm is permissible across the surfaces lying on the reference and step planes and a horizontal tolerance of 3mm is permitted when assessing whether a surface is visible from beneath the car.
McMrocks
McMrocks
32
roon wrote:
25 Aug 2018, 17:18
3.7.5 Tolerances
So could teams remove the slots in the side pod turning vanes and say that the small area seen from underneath is down to manufacturing tolerances?
Zynerji
110
McMrocks wrote:
25 Aug 2018, 20:35
roon wrote:
25 Aug 2018, 17:18
3.7.5 Tolerances
Kind of the point I was making.
And a +3/-3mm "flatness" tolerance could seriously be abused for "texturing" the underside of the floor...
roon
roon
412
An intentionally textured floor would be distinguishable from waviness due to manufacturing limitations.
ScrewCaptain27
577
Impressively shallow RW for Monza:
Via @AlbertFabrega
- Serj Tankian
Via @AlbertFabrega
Webber2011
Webber2011
M840TR
M840TR
315
mrluke
mrluke
Amazing they can have such a flat RW but still do better than the whole midfield on the twisty bits.
M840TR
M840TR
315
Interesting.
Zynerji
110
roon wrote:
26 Aug 2018, 00:35
I see nothing in 3.7.5 distinguishing these variances as "manufacturing variations".
I mean, what if my mold had 3mm bumps in it, and made my floor look like a golf ball? Do I just have to prove it was unintended? Or say, STFU. You can't question anything under 3mm variance!
Ashwinv16
Zynerji wrote:
31 Aug 2018, 02:51
roon wrote:
26 Aug 2018, 00:35
First off this whole golf ball thing will only help with flow attachment, which can be achieved through cheaper means, like the vortex generators placed in front of the floor, second you will have to proof that those were un intended but if they form a symmetery(Left and Right side of the central skid plane) FIA ain't gonna believe you.
P.S This whole golf ball floor texture is slightly confusing on how it will work, it makes more sense placed in the diffuser entrance. (That curved bit transitioning from the flat floor before the diffuser exit)
Halo not as bad as we thought
