McLaren MCL60
trinidefender
trinidefender
318
Re: McLaren MCL60
Henk_v wrote:
27 Jul 2023, 22:02
Given the ride height is 100% dictated by the eau rouge compression, you need all the stiffness you can get.
Not necessarily. There are a few options to alleviate that problem from bump-stops with varying stiffnesses to different rising rate springs and/or bellcranks allowing the car to be set up softer at slower speeds but stiffening up for those sections.
Farnborough
Farnborough
111
Re: McLaren MCL60
trinidefender wrote:
28 Jul 2023, 01:12
Henk_v wrote:
27 Jul 2023, 22:02
This is one of the areas in which the so called "anti dive" has an effect and how its arranged on some chassis. Notice how good (almost unaffected) was RB here last year.
It partly separates the consistent vertical component by supporting compression with geometry conflict, while leaving the true spring/torsion provision to cope with more conventional irregularities.
Tomsky
Tomsky
29
Re: McLaren MCL60
DiogoBrand
74
Re: McLaren MCL60
Farnborough wrote:
28 Jul 2023, 09:02
28 Jul 2023, 01:12
Henk_v wrote:
27 Jul 2023, 22:02
As far as I know, anti dive and anti squat are meant to control compression under longitudinal acceleration, like accelerating and braking, not vertical load due to downforce, lateral load or vertical change of direction, as is the case of Eau Rouge.
MCLvamos
MCLvamos
Re: McLaren MCL60
Tomsky wrote:
28 Jul 2023, 11:18
https://i.imgur.com/3nMmR9a.jpeg
No trims visible on the earlier images sent, so I assume they've brought multiple levels of DF rear wing, and it just so happened the higher DF one was the one put on during Thursday assembly (perhaps with an eye on the weather).
Farnborough
Farnborough
111
Re: McLaren MCL60
DiogoBrand wrote:
28 Jul 2023, 11:40
Farnborough wrote:
28 Jul 2023, 09:02
28 Jul 2023, 01:12
I put it in " " as others describe it as such, and yes agree with you in it's purest form as to effects.
But these more extreme drop of rear suspension leg (using RB as example) and difficult to fully judge because we cannot really see the top outer joint of those two components, have the capability to add conflict, hysteris and individual spring effect tuning to this vertical path.
If (you can can see the limitations of description) the two top arm are single component, then upward movement will initiate a torsion of the top single "crossbow" link rather than just vertical movement. This available to any vertical chassis load. That design was (obviously other chassis parts are influences) easily the least affected by the TD 039 imposition last year.
We've something to look for at least this year in relative performance in seeing if this team or others move nearer to parity.
CjC
CjC
Re: McLaren MCL60
Tomsky wrote:
28 Jul 2023, 11:18
Just circuit specific. No fundamental upgrades to the car.
Just a fan's point of view
Tomsky
Tomsky
29
Re: McLaren MCL60
f1rules
f1rules
621
Re: McLaren MCL60
rb vs mcl pics from
Thomas Maher
@thomasmaheronf1
f1rules
f1rules
621
Re: McLaren MCL60
and more close up from
Luke Smith
@LukeSmithF1
and picture from yesterday
djos
113
Re: McLaren MCL60
Tomsky wrote:
28 Jul 2023, 12:06
Considering how long PP spent working with Adrian, he might well be the best person to understand how Adrian linked the diffuser to the rear wing.
"In downforce we trust"
MrGapes
34
Re: McLaren MCL60
Testing two beam wing configs (Oscar High df, Lando Low)
Macklaren
Macklaren
Re: McLaren MCL60
I'm surprised they said circuit specific... This low DF wing looks like it it can be a universal solution except in places like Singapore. Particularly if it boosts drs
f1rules
f1rules
621
Re: McLaren MCL60
Thought: how its described, rbs effect and what mcl is trying to copy is the interaction between beamwing and mainplane to reduce drag, do we think it will get so developed that there will be a specific beamwing suited for each track or maybe just aoa, meaning if they know it needs to work from this velocity, faster then the fastets corner, then we do this angle, etc, so they can finetune for each track which speed the beamwing start to have effect?
MrGapes
34
Re: McLaren MCL60
f1rules wrote:
28 Jul 2023, 15:04
It would certainly be more cost friendly..than 5 rear wing assemblages
