Ferrari F2012
jonaliew
jonaliew
Re: Ferrari F2012
Crucial! Where have you been all this while!
Indeed, what is that mysterious solution? I reckon there is something that we can't see.
Alonso seemed to be wrestling the car with the new updates (which he was a master of control) but we definitely weren't far behind in terms of race pace. Let's hope FP3 would be positive and that we will be close in terms of qualy.
f300v10
f300v10
185
Re: Ferrari F2012
Old:
New:
The new diffuser appears to have a wider exit, with more horizontal expansion of the flow on the outer edge. Compare the width of the flat area on the outside of the tunnel section, and you can see it is much smaller on the new diffuser. There is also more outward curve visible inside the tunnel. This gets Ferrari closer to what most other teams are running in that area.
amouzouris
105
Re: Ferrari F2012
The exhaust ramp isn't new! if you go back to the Korean GP photos and Japanese GP photos you will see that it is the same!
jonaliew
jonaliew
Re: Ferrari F2012
amouzouris wrote:The exhaust ramp isn't new! if you go back to the Korean GP photos and Japanese GP photos you will see that it is the same!
+1. I can't tell the difference when comparing them side by side.
alogoc
alogoc
-10
Re: Ferrari F2012
FW flex comp.
THE F2012!
THE CAR THAN WON 2012 WORLD F1 CHAMPIONSHIP WHIT A TILTED ENGINE!
Huntresa
Huntresa
Re: Ferrari F2012
alogoc wrote:FW flex comp.
This pic better shows how high and low the noses are if anything
Reason: Removed image quoted from post above
Re: Ferrari F2012
Now this again?
Please, for crying out loud, stop posting stuff that has been dealt with on multiple occations. We all know the Red Bull flexes more, yet no one cares(anymore)
aral
aral
26
Re: Ferrari F2012
wesley123 wrote:Now this again?
Agreed. And did you see the flex in the Macca?
Forza
238
Re: Ferrari F2012
Another series of photos from today's Free Practice
Re: Ferrari F2012
where are the dampers,rockers arb/Inerter? It looks like the whole lot is not part of the gearbox but a separate unit ?
enz0
enz0
Re: Ferrari F2012
Seems like the reason for Massa's woes must be him not using the new diffuser.
Redragon
19
Re: Ferrari F2012
enz0 wrote:Seems like the reason for Massa's woes must be him not using the new diffuser.
Spanish press reported on an interview with Pat Fry that Massa problem was a mistake on the set up
http://www.as.com/motor/articulo/pat-fr ... mot_25/Tes
hendrix
hendrix
Re: Ferrari F2012
Marc Gene has said just before P3 that yesterday was a good day and all the evolutions worked fine.
scarbs
scarbs
393
Re: Ferrari F2012
Yes its a separate unit, STR do the same, while it seems a bit more complicated, it makes access to the clutch and gearbox much easier. other teams have to remove inerters\Heave springs\ARBs to get at the transmission.
0versteer
0versteer
Re: Ferrari F2012
what about Sauber ? is that a trend for teams with Ferrari engine?
By the way, Ferrari seems to be developing car, but not better than Red Bull... I have still some hope, I think the main parts may be introduced in the next race, rather than this one, because it is very difficult to change some parts slightly after straightline testing, there were no time...
or I'm still simply too optimistic
