A agree with you on the "full gas flow", not sure I understand.alelanza wrote:Hmmm... i definitely have no clue what you're talking about, do you have a link to the source you got this idea from? that may help me.WhiteBlue wrote:
If you avoid the throttle all together (for efficiency reasons) you get the full gas flow going through the engine. This is what people want for the blown diffusors.
You can't avoid the throttle, whether you use a plate or valve lift and timing to throttle an engine, you still need to throttle it, otherwise the partial load term wouldn't even exist, you'd be at WOT all the time.
Can't have it both ways. Removing the throttle helps at part load conditions more than at fully loaded conditions of course, but even a race engine spends time at part throttle. Won't hurt and in terms of advancing engine technology (which I think will be part of the aim in the new regs) its a good idea.alelanza wrote:For other readers. This also makes me think about the vacuum a race engine produces, perhaps someone with engine knowledge may be able to answer this. Given the aggressive cams/huge valve overlap of a racing engine, your vacuum signal is always extremely low, i can only imagine that on an 18k optimized setup it will be minimal. So with this in mind, would you gain anything by using valvetrain as a throttle device on an engine that spends most of its time at full throttle? could you really offset the increased mass and friction (which again BMW hasn't gotten to make sense past 6k rpms) on an F1 application?
What I'm referring to is the lack of the option for racing diesel's to use extremely high revs compared to the ignited petrol engines. Diesels have to stop with increasing the revs at one point and continue to get more power from capacity and load pressure. So diesel engineers probably have researched the technical resources for these (high pressure stratified direct injection, Variable geometry and multi turbos) much better.alelanza wrote:Hmmm... i definitely have no clue what you're talking about, do you have a link to the source you got this idea from? that may help me.WhiteBlue wrote:
I have already quoted this source three pages before. Please read this to get an idea for throttle less engine management and how to avoid or reduce pumping losses.
Throttling the air flow through an engine will soon look so antiquated as a carburetor now does compared to an injection pump. With solenoid valves, direct stratified injection, ion current measuring and narrow combustion window fuels things will soon look different.
Well all engines make power from torque and rpms, can't have one without the other really.WhiteBlue wrote: Regarding turbo and rpm have a look at the diesels. They make the power from torque which is an option for petrol engines as well. The engineers and the rule makers will have an option if they get the target power of 600 bhp from revs or turbo pressure.
I'm at a loss as to what you're saying.
In practice as well, BMW has been doing that for a while in production vehicles, it's the valvetronic stuff i referred to a few posts ago. I think other manufacturers do it as well, and i also believe it does not work in all part throttle conditions, ie they still have a throttle plate for certain scenarios.madtown77 wrote: You can remove the throttle if you could control the valves well enough in theory.
I agree with you that it's a good idea. But my question is, is it a good idea for F1? If a big (though perhaps not huge) manufacturer such as BMW hasn't gotten the technology to work in their street performance applications, how would F1 teams with much less $ and a much different focus get it to work?madtown77 wrote:
True, but if we use the valves to throttle the system, we'll also get a pretty decent degree of turbulence in the air swirling around the moving valves, so not lossless either, correct?madtown77 wrote:
*EDIT: Also, remember that even a fully open throttle is not lossless. Lot of turbulence at high air velocities on a throttle blade.
Gotcha, i guess it was the word 'reserve' that threw me off. Also i didn't realize we were talking about diesels, it was a few days since i had visited this topic.WhiteBlue wrote:What I'm referring to is the lack of the option for racing diesel's to use extremely high revs compared to the ignited petrol engines. Diesels have to stop with increasing the revs at one point and continue to get more power from capacity and load pressure. So diesel engineers probably have researched the technical resources for these (high pressure stratified direct injection, Variable geometry and multi turbos) much better.
Valve turbulence is a property of the valve. Anything you can do before then to reduce pressure drop will help you. I'm not saying it makes the system lossless, but it takes out a large turbulence source upstream of the intake which is of huge benefit even at a fully loaded condition.alelanza wrote:True, but if we use the valves to throttle the system, we'll also get a pretty decent degree of turbulence in the air swirling around the moving valves, so not lossless either, correct?madtown77 wrote:
I thought that was pretty obvious from reading the source I gave. With a throttle the power modulation is done by reducing the air or oxygen flow through the engine. This means you have a reduced efficiency and reduced gas flow.alelanza wrote:Yeah, i'll wait for WB's explanation on that one.madtown77 wrote:
Exactlyxpensive wrote:But what is interesting for the diffuser is the gas-flow out of the engine
Interesting, I didn't know the leaner mix produced more flow, why is that? And does having more mass flow means you're less eficient? ie more of the combustion energy is going towards the exhaust?madtown77 wrote:If you can run under lean A/F ratios you would get higher gas flow through the engine. If you could run it out to like lambda of 2, you theoretically get twice the gas flow. As I said a few pages back this is possible, but has not been done in an automotive application to my knowledge.
The amount of gas flow out of the engine is very well dependent of the use of a throttle. Let us assume that we use the same amount of fuel for throttle and throttle less operation.xpensive wrote:But what is interesting for the diffuser is the gas-flow out of the engine, which always will be a result of the amount of fuel burnt, if you don't burn any fuel I cannot possibly see what difference a throttle-less engine will make?
I couldn't agree with you more... however if you don't have some other way of limiting the air going into a petrol engine (e.g. by reducing valve lift for example) how will you avoid the very high high:fuel ratios at part load situations that will result in extreme temperatures and failed valves and pistons?Throttle less operation will give you more gas flow all other things being equal
