Yes why not? This is a good idea
I would make it as accessible as possible
It is now up on the Rules & Files section.machin wrote: ↑04 Oct 2017, 22:00Well I started off by updating the Introduction to Racecar Aerodynamics guide that I wrote a couple of years back... mainly this is just removing the old KVRC logos and replacing them with Mantium Challenge ones!
It can be download here:-
INTRODUCTION TO RACECAR AERODYNAMICS
Andre, perhaps you could link on the Mantium Challenge website?
Well, I must be doing something wrong here.LVDH wrote: ↑05 Oct 2017, 10:32I have also written an article about how to fix holes in the car geometry. If Chris gets the new version of the rules out in time, soon there will be immediate penalties for non-closed cars. So if you are having trouble, you might want to have a look to find out how to fix these issues:
http://mantiumchallenge.com/locating-ho ... mulations/
Hi LDVH, y-axis has the same direction of the wheel axis? I agree, it should be the most useful rotation.
and● Any bodywork visible from below, which lies directly above/below floor guide 2,
excluding the parts inside the rear wing volume, must be no more than 270mm
above the reference plane.
Does it apply to some winglets which would be visible through holes/cutouts in the floor in these areas? Maybe you have some example of illegal solution for better understanding?● Any bodywork visible from below, which lies directly above/below floor guide 3,
must be no more than 125mm above the reference plane
The important thing to pay attention to with K3.3 is the final point - if you were to draw lines along the surfaces visible from below in those regions, in directions parallel to the X or Y axes, then there shouldn't be any gaps in those lines (looking at each half of the car separately, and ignoring the gap that forms between the two guides in the wheel well region). This rule means that almost any cutout in the floor in those areas is not legal in the first place. But yes, if there was a cutout which was still legal somehow, then those height rules apply to any bodywork visible from below, except for the parts inside the rear wing volume. If you have a particular design in mind, then we could continue the discussion through PMs.schwepes wrote: ↑07 Oct 2017, 16:06Noob question... Can sameone explain me two points from the floor rules K3.3?and● Any bodywork visible from below, which lies directly above/below floor guide 2,
above the reference plane.Does it apply to some winglets which would be visible through holes/cutouts in the floor in these areas? Maybe you have some example of illegal solution for better understanding?● Any bodywork visible from below, which lies directly above/below floor guide 3,
Thanks.
NEVER MIND
